Tool Talk Discussion Forum
Shop Press - anyone make one or
ShepFL
09-07-2003 14:22:07
got a lead on an inexpensive one. Would be handy to have one around. I have some I-beams lying around and and old bottle jack. Thought this could be something I could build over the winter.
Neal
09-08-2003 17:49:19
 Re: Shop Press - anyone make one or in reply to ShepFL, 09-07-2003 14:22:07
I made mine out of 4 inch I beam and used some car trunk springs for the jack cylinder return. I've had it about 15 years and it works great. I also made parts to use it as a brake press for making parts and brackets. I have it set up to use a 6 or 12 ton jack. I rarely need more than the 6 ton to do the job at hand. It presses bearing on and off nicely.
Fred OH
09-08-2003 06:23:50
The mast from an old forklift works well as the upright parts...about 5/8" thick (nobody will steal it) and a 50 ton bottle jack from Harbor Freight will take care of the pushing. I found some 10" channel with about 5/8" wall thickness for the cross pieces. Works as well as the Dake 50 ton press that I had...except for no gage...now if I could figure out how to put a gage on the jack...the jack price was around $189 with free shipping...as I recall. L8R....Fred OH
Alan K
09-07-2003 19:54:23
Depending on what you plan to use it for, you might consider putting a electric motor and hyd pump on it, you won't regret it. We did on ours. We had found a frame and used an old 5" hyd cyl,hyd pump from a JD combine, and a two way hyd valve. It has got some power.
ShepFL
09-08-2003 06:58:07
 Re: Re: Shop Press - anyone make one or in reply to Alan K, 09-07-2003 19:54:23
Now that is an idea!! Thanks!!
wh
09-07-2003 17:09:28
greetings!! i have made several. used 6" channel for sides. not a real problem. can send you some pics if interested. wade
ShepFL
09-07-2003 17:25:48
 Re: Re: Shop Press - anyone make one or in reply to wh, 09-07-2003 17:09:28
Hey Wade!
Pics sound great. Use the above email but delete the (remove) from the addy. Thanks in advance.
wh
09-07-2003 19:10:51
 Re: Re: Re: Shop Press - anyone make one or in reply to ShepFL, 09-07-2003 17:25:48
will do - give me a couple days to get them/find them. wade
BFarr
09-09-2003 17:52:14
 Re: Re: Re: Re: Shop Press - anyone make one or in reply to wh, 09-07-2003 19:10:51
Hay how about including me in the email pictures
It sounds like a great shop project for students
[email protected]
wh
09-08-2003 09:12:51
PING!!!
