Tool Talk Discussion Forum
Gas Tank Leak?
Paul
09-07-2003 13:04:50
Can someone recommend a good gas tank sealer for the inside of a leaking 12 gallon gas tank on a JD tractor? The tank has been removed.
Thanks, Paul
wboston
09-07-2003 18:31:30
 Re: Gas Tank Leak? in reply to Paul, 09-07-2003 13:04:50
I used POR 15 on a very rusted Ford gas tank with great results. Try www.porstore.com
Rod (NH)
09-07-2003 16:07:38
Hi Paul,
I have had excellent luck with this epoxy sealer. I did the tank on my AC-B last year and will do the tank on my Oliver 77 this fall with the same stuff.
third party image Rod
George
09-07-2003 15:31:27
The sealants works best on pinholes and seam leaks, plus it slows down internal rusting. Swing by your local motorcycle dealer as they usually carry tank sealer kits, which consists of the sealant along the required cleaner and etchant. (They all seem to be about the same, in my opinion.) Seems like the last kit I bought a couple years ago was something like $24 for a quart kit which will do several tanks.
tbear
09-07-2003 15:08:46
There is a process called renu that plastic coats the inside and outside of tanks ask your local radiator repair shop about the process or another another process similar to this it is not expensive at all and you will be happy with results goodluck
Paul
09-10-2003 03:19:53
 Re: Re: Gas Tank Leak? in reply to tbear, 09-07-2003 15:08:46
Thanks for your advice guys! I have considered many options and because the tank is in bad shape (some holes, etc) I plan to fiberglas the outside and epoxy line the inside. I will try the Caswell liner that Rod suggested.
Thanks again! Paul
