RayP(MI)
09-07-2003 10:20:58
Re: Propane conversions in reply to Bill, 09-07-2003 06:07:14
Sorry, can't help you much on the propane conversion, but if you find something, I'd like to know - would like to convert the Coleman 8Hp/Briggs I have. Do you heat with propane, if so, tapping into your main tank would provide you with quite a bit of available vapor. Aslo, propane normally vaporizes down to -20F, so you probably would be OK to run most of the time anyway. (I'm new to propane, having had nat gas for years. Just lost it.) I'm concerned what happens to my need for furnace heat in the extreme cold temperatures too. As far as the Vangard, if that's the same engine I put on my lawn tractor, it is a pretty good engine - you don't need to apologize for having one. We've beat up on ours something fierce, and it keeps on going! I have a cheapy generator too - as long as you're only using it as backup, it'll last a long time, if you care for it properly. If you're powering a worksite 40hours or more a week, a better unit might be appropriate. For now, be happy with what you've got - I'tll keep your house warm, and your beef cold thru many outages. Have you contacted several propane dealers - they often will run vehicles on propane, or be able to refer you to firms that do conversions.
