Tool Talk Discussion Forum
Vapor pressure of propane
chem
09-06-2003 10:38:43
Could you pls tell me best soure to get vapor pressure data online for propane?
Try this chart
09-10-2003 20:41:19
 Re: Vapor pressure of propane in reply to chem, 09-06-2003 10:38:43
http://www.glacierbay.com/ptchartpropane.htm
Paul Janke
09-06-2003 20:32:51
Propane distributors should have small handbooks which would have the information you want. It will also have information on required line sizes, etc. I had one in the truck all the time when I used to deliver propane.
Rod (NH)
09-06-2003 12:12:59
Hi Chem,
You could always use Google :).
Anyway, it's 123.7 psia. See section 9 (physical and chemical properties) of the MSDS.
third party image Rod
big fred
09-06-2003 16:42:26
 Re: Re: Vapor pressure of propane in reply to Rod (NH), 09-06-2003 12:12:59
Rod, like any gas, the vapor pressure is dependent on the temperature. I would imagine chem is looking for either a chart or a table. I agree with you, though, he can probably find it with a google search as easy as we could. Sometimes folks want the easy way out.
Rod (NH)
09-06-2003 17:31:09
 Re: Re: Re: Vapor pressure of propane in reply to big fred, 09-06-2003 16:42:26
Hi Big Fred,
You are correct, of course. I quoted the 123.7 psia from the linked MSDS without thinking about the variation with temperature. In re-checking the MSDS I find that no temperature is stated. Odd. I suspect the VP given there is for standard temperature of 70 deg F, but that is not clear. Thanks for the clarification.
