Where is my 9N Hydraulic Safety Valve?
Mike
09-10-1998 17:37:48
My safety valve is not where it should be. All thats there is the control valve.Could it be somewhere else? Its a 47 Ford 9N
DaBrow
09-10-1998 18:57:12
 Re: Where is my 9N Hydraulic Safety Valve? in reply to Mike, 09-10-1998 17:37:48
: My safety valve is not where it should be. All thats there is the control valve.Could it be somewhere else? Its a 47 Ford 9N
A '47 is a 2N. All 9n & 2n serial# start with the prefix 9N. There are several charts on this board. I know notttting able your orginal request,sorry.
JerryU
09-10-1998 18:38:44
They are on the very bottom on the rear of the pump above the pto shaft under the control valve
don't think Henry made any other style of pump. Pull the PTO shaft and you should be able to get at it.
JerryU
Dub S
10-02-1998 21:09:02
 Re: Re: Where is my 9N Hydraulic Safety Valve? in reply to JerryU, 09-10-1998 18:38:44
: : My safety valve is not where it should be. All thats there is the control valve.Could it be somewhere else? Its a 47 Ford 9N
: They are on the very bottom on the rear of the pump above the pto shaft under the control valve
: don't think Henry made any other style of pump. Pull the PTO shaft and you should be able to get at it.
: JerryU
Henery did not make them, Harry did. The valve screws in to the rear of the pump just below the pto shaft & above the control valve.
Dub S
10-02-1998 21:05:58
: JerryU
