Tool Talk Discussion Forum
What type of respirator for sand blasting?
Dave
09-04-2003 20:17:08
What do you occasional blasters use to keep the old grit out of your lungs? Got a 100lb pressure type I just bought and am ready to use it. I have the full canvas hood to wear but need info on a respirator. Thank you!
Robert
09-05-2003 05:57:49
 Re: What type of respirator for sand blasting? in reply to Dave, 09-04-2003 20:17:08
You asked about a respirator, and the best would be a full hood type, like others have suggested, with a fresh air supply pumped in.
If you're asking about a dust mask, then you would want one that has a NIOSH rating of at least 95, usually it will have two rubber bands with a nose clip incorporated for sealing.
The other choice, as stated, is to use a non-silica media. The dust mask is still a good idea to keep the crud out of your nose and lungs though.
Good Luck!
David - OR
09-05-2003 05:48:48
There's another way around this. Look in the Yellow pages under "abrasives" and find a product like "Vitrogrit" (crushed recycled glass) or "Black Beauty" (processed coal slag).
Unlike common sand, these products do not contain free silica. They come in 70 to 100 pound bags, graded for size and convenient to use. No sifting needed and the blaster does not clog up. Typical cost is 10 cents per pound or so. For the amount of blasting one can do with one of these smaller pressure pots, it isn't even worth sweeping up and trying to recycle the abrasive.
Use of these products eliminates the primary health hazard, although there are still secondary hazards from the paint, etc. being blasted off the metal. I usually wear a two-elastic-band dust mask and work outside and upwind of the article being blasted.
Farmer/Paul
09-05-2003 03:24:18
Blasting sand is made from silica, the particles get in the lungs an give you a condition called silicosis (sp?).
Wayne
09-04-2003 21:01:53
Hey Dave, the main thing you need is a respirator that will filter silica dust as that is the hazard associated with blasting sand. I've got a 300lb pressurized pot blaster and it already had a carbon filtered, pressurized breathing supply line, going to a regular hard type blasting helmet, incorporated in with it when we got it. If your gonna be doing alot of blasting this is the way to go. During the summer months it gets awful hot inside the helmet even with a constant supply of air being pumped in, so I hate to imagine a full hood and a respirator with no air supply at all. Just my .02... Good luck and happy blasting.
Art Guzman
11-18-2003 12:13:12
 Re: Re: What type of respirator for sand blasting? in reply to Wayne, 09-04-2003 21:01:53
I do small jobs in my back yard where I sand blast etching on mirrors and glass. What would I need in order to protect myself.
Should I buy something new or used.
Art
Jailkeeper
09-04-2003 23:01:45
Ditto on the helmet and pressurized air supply. It also keeps the lens from fogging up on the inside so you can see what you're doing.
I don't know what a setup like that would cost now, but the benefits would far outweigh the expense. Nothing worse than blasting away at something you can't see.
I had the pleasure of blasting the inside of a 4000 gal. tank on a Terra-Gator. It had been used to haul sludge and hog manure. Used about 800 pounds of sand to get it clean, then had to scoop all the sand and scale out a 6" hole in the bottom of the tank. What a nightmare.
Wayne
09-05-2003 20:36:05
 Re: Re: Re: What type of respirator for sand blast in reply to Jailkeeper, 09-04-2003 23:01:45
Hey Jailkeeper, the biggest job I did was a 405 Koering crane complete with about 60' of boom.It didn't smell like manure, and I didn't have to scoop everything out of a 6 inch hole, but when all was said and done I had used right at 4200lbs of sand, and spent about 20 hours blasting on it. Thank goodness for a air cooled helmet and the fall of the year. Then we got two spray guns working and went through 4 unmixed gallons of orange paint (about 8 when mixed), and about 4 more unmixed of black, not to mention the primer. Let me tell you, this was one heck of a job. After this doing something small like a truck frame or antique gas pump, etc doesn't seem like that big of a deal. Mainly though it made me glad I don't actually do it full time for a living....
Slowpoke
09-05-2003 00:14:24
Grainger 2002 catalog: abrasive hood, cape, short hose: $466.
25' hose: $66
Compressor air filter kit: $212
Total $744
Might as well pay to have someone do it.
Jailkeeper
09-05-2003 17:07:27
 Re: Re: Re: Re: What type of respirator for sand b in reply to Slowpoke, 09-05-2003 00:14:24
Holy Cow Batman!!!
Good thing it was someone else's stuff I was using. I didn't think the pressurized helmets would be that expensive. Yeah, for that much money I'd hire it done. I guess it depends on how much you use your blaster though.
