Tool Talk Discussion Forum
Where can I find schematics for a mig welder ( to
Tim
09-04-2003 11:46:29
Hi there Does anyone know of or have a set of wireing and part diagrams for a Mig welder
which i can build at home??
Thanks Tim
Kennyp
09-04-2003 20:02:03
 Re: Where can I find schematics for a mig welder ( in reply to Tim, 09-04-2003 11:46:29
Like Mark says, plus it is my understanding that a MIG transformer is a constant voltage type. This is a different cat than a standard power transformer. Now if you asked to build/wind a stick, arc welder, I would say go to it. Amature radio people used to do it all the time. I did some of it. You would need a big core and lots of BIG wire. Still cheaper to buy one. The import welders are very cheap. E-bay. Quality unknown, but cheap.
MarkB
09-04-2003 18:19:08
I think you would have problems building one for less than you can buy one new. Ever picked up a welder? That weight is mostly transformer. A 150 amp MIG welder needs about a 4 KVA transformer. And diodes that will handle 150 amps aren't cheaper either. Don't forget you need a variable speed wire drive; even the factory units can be aggravating to get working right. You'll need a gas valve, too. And the weld gun.
Good luck!
Mike W
09-07-2003 20:57:43
 Re: Re: Where can I find schematics for a mig weld in reply to MarkB, 09-04-2003 18:19:08
I use a 24v battery charger to drive a Miller wire feeder. It operates at 26v and 100 amps. Look around, you can sometimes pick up surplus stuff cheap.
