Backhoe squealing
Tony
09-10-1998 16:37:37
I'm using a 750 Woods 3ph backhoe. It squeals when
lifting the boom with the bucket loaded. I don't remember it doing that before it blew out a line.
Everything else seems to be working fine. Should
I have bleed the hyd. system when I changed that
line? Thanks Tony
Tyler
10-04-1998 22:26:40
 Re: backhoe squealing in reply to Tony, 09-10-1998 16:37:37
Did you refill the tank with hydraulic oil?
: I'm using a 750 Woods 3ph backhoe. It squeals when
: lifting the boom with the bucket loaded. I don't : remember it doing that before it blew out a line.
: Everything else seems to be working fine. Should
: I have bleed the hyd. system when I changed that
: line? Thanks Tony
joe m
09-10-1998 20:01:47
: line? Thanks Tony
tony
hyd systems self bleed after you crank the tractor
squealing is from either a line being crimped (was the new one a made hose or oem?)
or it could be that it is the overload valve bleeding pressure from overloadind the bucket
hope this helps.....
JK MN
09-11-1998 11:50:37
 Re: Re: backhoe squealing in reply to joe m, 09-10-1998 20:01:47
: : I'm using a 750 Woods 3ph backhoe. It squeals when
: : lifting the boom with the bucket loaded. I don't : : remember it doing that before it blew out a line.
: : Everything else seems to be working fine. Should
: : I have bleed the hyd. system when I changed that
: : line? Thanks Tony
: tony
: hyd systems self bleed after you crank the tractor
: squealing is from either a line being crimped (was the new one a made hose or oem?)
: or it could be that it is the overload valve bleeding pressure from overloadind the bucket
: hope this helps.....
Tony,
Which hose blew? Is the hose ID the same size? A smaller ID hose will cause restriction especially if it is the return hose. Anything else change, such as quick coupler ends, tractor, make or model, engine RPM, or is there a piece of the old hose caught somewhere?
Slow Poke
09-12-1998 06:01:31
 Re: Re: Re: backhoe squealing in reply to JK MN, 09-11-1998 11:50:37
: : : : I'm using a 750 Woods 3ph backhoe. It squeals when
: : : lifting the boom with the bucket loaded. I don't : : : remember it doing that before it blew out a line.
: : : Everything else seems to be working fine. Should
: : : I have bleed the hyd. system when I changed that
: : : line? Thanks Tony
: : tony
: : hyd systems self bleed after you crank the tractor
: : squealing is from either a line being crimped (was the new one a made hose or oem?)
: : or it could be that it is the overload valve bleeding pressure from overloadind the bucket
: : hope this helps.....
: Tony,
: Which hose blew? Is the hose ID the same size? A smaller ID hose will cause restriction especially if it is the return hose. Anything else change, such as quick coupler ends, tractor, make or model, engine RPM, or is there a piece of the old hose caught somewhere?
If it started doing the squealing right after you put the new hose on then there is a good chance that the new hose has a restriction in it.
I have had this happen three times now where the new hose will not work right so I put another new hose on and it works perfect. [Good luck convincing the salesperson that the hose was defective].
Tony
09-12-1998 05:54:20
: : tony
: Tony,
Thanks,
I'll check those things and report back. Can I adjust the overload valve? Thanks again, Tony
