Tool Talk Discussion Forum
1963 4000 problem
A J Crochet
09-03-2003 15:22:58
She started acting up, missing, white smoke and barely running to make it to the barn, replaced fuel filter and fuel, started up good, ran 30 min anddid same, does this each time, runs 20 or 30 minutes and the same, slows down, misses and white smoke, while running I cracked each injector and found each injected is working.
any help would be appreciated thanks A.J.
ATW/WA
09-03-2003 19:13:44
 Re: 1963 4000 problem in reply to A J Crochet, 09-03-2003 15:22:58
AJ, Your white exhaust wouldn't happen to have a slight aroma of antifreeze would it? Thirty minutes run time is just about enough to warm the block up. so if you happened to have a crack or headgasket leak it would show those symptoms.
I hope I'm wrong.
ATW/WA
