Tool Talk Discussion Forum
Welding mild steel to cast???
Andy
09-03-2003 10:55:26
I have an very old potbellied stove. I think it will need a new flange for the stove pipe. It's pretty brittle stuff. I have some nickle rods, should I try these or gas weld it with a cast rod? thanks, Andy
Russ
09-04-2003 18:37:08
 Re: Welding mild steel to cast??? in reply to Andy, 09-03-2003 10:55:26
Why not make up a flange out of mild steel and bolt it on with a bunch of little stove bolts? I think welding disimilar metals together and then heating and cooling would crack the stove.
Andy
09-05-2003 05:34:41
 Re: Re: Welding mild steel to cast??? in reply to Russ, 09-04-2003 18:37:08
There is a pretty solid flange right now. The problem is that it's only about 1/2" tall right now. I thought it would be a lot easier to install if I bent a new rim and welded it to the existing one to make it taller.
fred kobs
09-03-2003 20:08:27
I think I would try brazing it. I'm nowhere near a pro welder but have brassed dissimilar metals like these with luck.
reply
09-04-2003 16:38:47
 Re: Re: Welding mild steel to cast??? in reply to fred kobs, 09-03-2003 20:08:27
Would I have to worry about the brass softening up with a hot fire?
