Tool Talk Discussion Forum
String Trimmer - again
Chuck, WA
09-02-2003 08:58:07
I've read and followed some of the previous posts on getting string trimmers tuned up and running again, but still problems.
I have an Echo, model 1100 (I think) that I bought a number of years ago for light once or twice a month use around the yard. At the time, Ech was the most highly recommended trimmer by my local small engine shop, not a KMart blue light special.
It replaced a Sears that I had used for years for everything from light yard trimming to heavy duty clearing of blackberry bushes with a blade in place of the string head. I thought the Echo would be an improvement when the Sears finally became too cranky.
The Echo held up OK, but started getting balky all too soon. Took it back to the shop where I bought it and they essentially told me it was not worth working on since repair would cost a fair fraction of a new one. HUng it on the garage wall and didn't use it for a couple of years.
Last year I needed for it again when we moved onto some acreage and I needed to trim around sprinkler risers. I took it apart and cleaned it, and replaced the fuel filter. It ran OK, but I never could get it to idle. It ran at high speed, but when I let the throttle go, it would wind down and die. This year, it finally got to where it wouldn't run long at all.
One recent post suggesting cleaning the muffler. A week or so ago, I tore it down yet again and cleaned the carb, and checked the fuel filter - looks good - and cleaned the spark plug. I also cleaned the spark arrester (which was pretty well plugged) and muffler, set the hi and lo screws to 1-1/2 turns and tried it. I was able to get it to start and it will run at high speed, but I can't seem to get it to run slower, and if I come off the throttle all the way, it dies. The speed increases as I close down the hi speed screw until it's all the way in. The lo speed screw doesn't seem to do much, although it's hard to tell since I need to hit the throttle off and on to keep it running and adjust and check between throttles.
Any suggestions I might try to get it running smoothly again?
Lyle, IA
09-03-2003 21:06:30
 Re: String Trimmer - again in reply to Chuck, WA, 09-02-2003 08:58:07
Im an Echo dealer for 20 plus years and if your still having trouble e-mail me your phone # and I will help you through this.
Chuck, WA
09-04-2003 06:25:09
 Re: Re: String Trimmer - again in reply to Lyle, IA, 09-03-2003 21:06:30
Lyle...Thanks for the offer. I'll try some of the suggestions posted here tonight, then if I still haven't resolved it, will take you up on it. In the meantime, I've e-mailed you with my e-mail address.
Tom
09-03-2003 13:11:38
You may have a crack in a fuel line. Have you removed each line and tested for leaks? Also, spray all the passages in the carb with carb cleaner - it will disolve all the deposits. I have never had any trouble with my Echo, but I allways use gasoline not over 2 months old and I use Stabil in every drop of fuel it has ever burned in all these years.
Chuck, WA
09-04-2003 06:17:17
 Re: Re: String Trimmer - again in reply to Tom, 09-03-2003 13:11:38
Tom...Thanks for the reply - new fuel lines, so not likely. I will try carb cleaner. Did that last year when I first got it running after the long unused period, but of course, clogged exhaust screen probably part of the problem at that time. Will try it.
Jake
09-03-2003 07:44:38
I've read through your post and replies.
I agree you have something inside the carburetor that is plugged. Especilly after you said it hung on the garage wall for several years. Those little carbs can have check valves, and other things hidden inside. I've seen stuff like old dried pancake syrup in those carbs from having fuel left in them. This stuff will be deeper inside than you uncovered by removing the diaphragm and primer bulb. Having the info about your carb would be a great help. Most of those little carbs are Tillotson or Walbro or Nikki or??? Look for a brand name on the carb, usually they are maked with a model ID and a spec ID. After you know that, then you can look up some information. Any good small engine place should be able to help after you have that information. Problem is finding a GOOD place that has people who know what they are doing. Too many out there that have no clue and should not even be in business.
Chuck, WA
09-04-2003 06:14:41
 Re: Re: String Trimmer - again in reply to Jake, 09-03-2003 07:44:38
Jake...Carb is a Zama and the numbers I see on it are K29 and just below that 24E. Went out to their web site and their reference chart shows a carb that has a K29 in the number, and the applications chart shows that the Echo GT2000 uses it, but I guess my GT1100 is too old to be on their chart.
I am talking to my local Echo dealer/repair shop about cost of replacement carb or parts, but his parts listing doesn't include the GT1100 and I didn't have the make and model yesterday. I'm dropping by there with the carb today to let him take a look at it. But, before I buy a replacement, I'll try following up on a couple of the replies - probably tonight.
Still open to comments.
Thanks!
Chuck, WA
09-03-2003 12:38:07
Jake...I'm inclined to agree with something being plugged. I did notice the make of the carb on the plate that covers the diaphragm, but didn't notice a model or spec. Also, can't recall the make, but will check it and post back tomorrow.
Right on regarding GOOD small engine shops - very rare! Most places that service anything anymore just replace major subsystems rather than try to figure out what the problem is - can't afford to spend the time to really troubleshoot or pretty quickly the labor cost is more than new. The shop where I bought it was pretty good, but as more and more people discovered that, they got very busy and then the slide started. Now, gotta find a new "good" one. Kinda like finding a good doc these days...once you find him and word gets around, he gets so busy he can't spend more than 30 seconds with you. Progress!
john
09-03-2003 07:39:21
I have a echo srm-210 its great (so far)
my manual says under troubleshooting runs but dies or does not accelerate properly--check, clean or replace--- air filter; fuel filter; spark plug; carbuator; cooling system; spark arrestor screen and exhaust ports. sounds like you have done all of these. so the only thing I can say is! echo says to REPLACE the carburetor once a year or 600 hrs for commercial use. I know you do not use it for commercial use but this tells me even echo thinks their carbs need replaceing and do not last even if rebuilt. if you are sure your exhaust is completly clean I would also check your lubrication on your gear housing and flex drive shaft. may be bogging the motor down at a idle because of hanging up. HOPE THIS HELPS JOHN
Chuck, WA
09-03-2003 12:31:15
 Re: Re: String Trimmer - again in reply to john, 09-03-2003 07:39:21
John...yeah, it helps. Makes me begin to think about replacing it altogether. Don't know what a carb costs, but can't be under $25 or $30, then what next? Besides, replacing the carb every year is outrageous! I know the string head is worn but still working so it will probably go next. Maybe I need to bite the bullet and start out next spring with a new one. Will price a carb then decide.
Thanks!
cb
09-02-2003 21:27:22
I have an Echo trimmer and it was doing the same thing as yours. Was about to throw it away and go get me another cheap throwaway when a friend told to take it to be fixed. I watched the guy work on it and the problem was a screen under the Muffler that was almost stopped up. He brushed and used his lighter to clean it. He said I was using the wrong oil for the echo and to only use Echo oil for it. Since then it has run fine. Hopes this helps.
Chuck, WA
09-03-2003 05:56:18
 Re: Re: String Trimmer - again in reply to cb, 09-02-2003 21:27:22
cb...thanks...but already tried that. It was plugged, and I cleaned it. Problem continues.
treeboy
09-02-2003 17:45:31
chuck, my 2 cents,,,set the hi /lo at 11/2 @ start trimmer. warm engine. (fresh fuel) i hope.. engine warm increase engine speed with throdle, turn high jet in slightly to a point that the engine still has a slight miss sound NOT "ascreemen demen" now if you have turned the hi in over a 1/2 turn then you should have set the jets at 1 turn out to begin with... if you made just a slight adjustment then its time to adj. the lo jet needle,,, baack it out if engine starts to die turn back in slightly... see if carb has a idle set screw that bumbs up to the butterfly if so this may need screwed in somewhat
phew. i hope this is a help, its hard to put it to print not seeing the carb..
Chuck, WA
09-03-2003 06:00:44
 Re: Re: String Trimmer - again in reply to treeboy, 09-02-2003 17:45:31
treeboy...Thanks! will try that. Will probably be this weekend, so may not reply here with results until then. Yeah...hard not being able to see carb. If I had a digital camera, would post a pic or two.
Incidentally, tried setting the throttle idel adjust screw to keep revs up enough to not die, but even with it all the way in, still doesn't keep it running.
Trevor
09-02-2003 11:09:16
Sounds to me like the low speed jet is plugged. I don't know much about Echo carbs but that is what it sounds like.
You said you cleaned the carb. What did you do?
Can you remove the low speed jet? Can you get a replacement?
Just a couple of thoughts.
Chuck, WA
09-02-2003 13:10:02
 Re: Re: String Trimmer - again in reply to Trevor, 09-02-2003 11:09:16
Trevor...the carb has a flat "plate attached to each of two sides. One is more or less a blind plate with flow channels machined in the inside and the other is a retainer for a primer bulb - also with flow channels. One goes on over the diaphragm. I took the carb off the engine, and removed both plates and cleaned all with gasoline. I carefully probed whatever holes I could with a fine wire, and dislodged something plugging one hole. On the side with the primer bulb, I cleared something that felt like a blockage in one of the two holes that lead to tubes that connect to the tank - one goes to the filter and the other just is open to the tank. The other had what could be some kind of a blockage, but it also felt like it could be a flexible check valve. I was careful to NOT clear it when I realized that it could be a valve that works with the primer bulb to suck gas into the bulb, but ther didn't seem to be any way to get to it other than probing with a wire.
There is a screw that holds what looks like a plunger assembly in the carb body under the diaphragm. I didn't remove that since I'm not experienced enough to know for sure what I might damage.
Do you now of any web sites that might show an exploded view of a typical 2-cycle carb and generically explain how they work? I have a rough idea, but it might help to know what the various parts are.
I didn't see anything that I could identify as being low and high speed jets. The two screws screw directly into the carb body, and any jets seem to be imbedded in the carb. There are some plugged holes that I assume were used during assembly for inserting parts - maybe the jets?
If that's of any help, I'd appreciate any further comments.
Thanks!
kwright
09-05-2003 19:27:21
 Re: Re: Re: String Trimmer - again in reply to Chuck, WA, 09-02-2003 13:10:02
I've never done much with trimmers, but I do rebuild, recondition & restore vintage Japanese motorcycles. I've done my share of work on 2-stroke carburetors.
When I need to THROUGHLY clean a carb, here's what I do. Note that I take digital photos of each and every step of tear-down to aid in reassembly:
Completely disassemble, including EVERY part I can remove.
Soak all parts (except rubber/vinyl if at all possible) in carburetor cleaner for several days, even up to a week. I *never* rush this step... I've learned from experience it's best to let the chemical do it's work. I use a gallon container of carb/brake cleaner which comes with a dip basket (Auto Zone is one place to get this). The parts should be completely immersed in the cleaner.
After removal from the soak, I use at least one can, often more, of spray BRAKE CLEANER to thoroughly hose down everything... all passages, orifices, exterior, interior, etc. I find brake cleaner dries faster and leaves the parts squeaky clean, better than regular carb cleaner. I don't use carb cleaner much anymore.
Next, I use compressed air, blowing both ways through all passages, especially through the needle and jet openings. In fact, I usually do the brake cleaner/compressed air routines two or three times in a row.
I then reassemble, using the digital photos as a guide if necessary. I rarely have a problem getting the filthiest carbs back in running condition following this routine.
Hope this helps...
