Tool Talk Discussion Forum
welding front axle support?
rod
09-01-2003 05:40:38
Hi all my cast front axle support is broken off quite a big chunk has to be welded it mainly only supports the radiator on one side has anyone used the muggyweld 77 rod they make some amazing claims for it at www.muggyweld.com they claim no preheating or peening is necessary cost is pretty high for just 7 rods regards
rod
T_Bone
09-01-2003 09:48:14
 Re: welding front axle support? in reply to rod, 09-01-2003 05:40:38
Hi Rod,
Your talking about the bolster support which is cast steel (not cast iron) and can be welded with any of the common electrodes, 7018, 6010, 6011, 7014, 7024, etc.
Any electrode bought in less than 50lb quanitys is expensive.
Steve from US Alloys pops in from time to time with great info and also carry's some specialty rods in small qunaitys.
T_Bone
rod
09-01-2003 10:47:22
 Re: Re: welding front axle support? in reply to T_Bone, 09-01-2003 09:48:14
T bone I am wondering if is forged steel? is there any special rod for that I have 7018 and 6011 for my lincoln 225 stick welder
regards
rod
T_Bone
09-01-2003 18:50:05
 Re: Re: Re: welding front axle support? in reply to rod, 09-01-2003 10:47:22
Hi Rod,
You will need to be sure the mfg rates it's electrode for AC machines is all you'll need. Alot of electrodes are rated both AC/DC and it will list first preferance first, like AC/DC, AC would be the first choice and DC/AC, DC would be first but will work well AC or DC.
Some mfg electrodes will not work well on AC.
T_Bone
