Tool Talk Discussion Forum
Ford tractor starter
Louie
08-31-2003 06:07:26
The bendix goes in to far about 1/4 of a inch it binds on the flywheel starter gear. It has a new bendix and a new flywheel ring gear It must off did it before I put these on because it broke the bendix before Can You tell me what is wrong Thank You Louie
ATW/WA
08-31-2003 12:58:11
 Re: Ford tractor starter in reply to Louie, 08-31-2003 06:07:26
Louie, It would help to know what model/year tractor you are talking about. If per chance this is a 9N, 2N, 8N; there are some new versions of Bendix that require grinding out the starter opening on the tractor housing( if this is not done, really bad things happen... :,o( ..). Other models have their own issues. Check the link below.
HTH ATW/WA
PS. If the afore mentioned information does not apply to your tractor, please post back with additional info.
