Tool Talk Discussion Forum
Air hammer chisels
Bus Driver
08-24-2003 17:40:54
The small air hammer chisels are too short for me sometimes. But I have not found longer ones. Are they available in longer lengths? I looked at Northern and theirs are the same short ones I already have. These are the air hammers held in one hand and use a spring to retain the chisel. Where to get longer chisels?
Fred OH
08-29-2003 07:11:02
 Re: Air hammer chisels in reply to Bus Driver, 08-24-2003 17:40:54
I'd just slice the small chisels in two with the chop saw and weld a piece of tool steel in the middle...kinda...sorta see how good you are at welding...cause if they aren't welded right...they will probably break. Experiment...You can find a way. L8R....Fred OH
John
08-25-2003 15:24:58
Try this place.. Ajax tools makes the cutters used by Fire Departments.
http://www.motionnet.com/cgi-bin/search.exe?a=sc&no=8876
TimV
08-25-2003 13:10:25
Bus Driver: McMaster-Carr's got them up to 18".
Gene Davis
08-24-2003 18:28:52
I found some at the Lowes Home Improvement Center for mine. standard shank size seems to be .401
