Tool Talk Discussion Forum
Stihl FS 36 Trimmer - Repair or Replace?
kwright
08-23-2003 18:03:35
I have a five year old FS 36 trimmer that recently siezed up. Not sure why exactly, as it's never had a problem before and has been well cared for. In any event it happened, so I pulled it down and found it was stuck good and tight. Eventually got it apart and the piston is scored pretty badly in one spot, as is the cylinder, and of course it took out the ring in the process.
My question: is it worth repairing? It'll need a new piston and ring for sure, probably a new cylinder as well.
As I've never worked on a very small two-cycle such as this before, I don't know if an oversize pistons & rings are even available (as they are for motorcycles which I am experienced with rebuilding). Otherwise, a new standard size piston, ring and cylinder will be required.
My gut tells me the cost of parts - assuming they are available - will probably be more than the value of the unit... but I thought I'd ask around first.
John in MA
08-24-2003 18:59:54
 Re: Stihl FS 36 Trimmer - Repair or Replace? in reply to kwright, 08-23-2003 18:03:35
The FS36 is a Ryobi. I doubt the cost of parts would be reasonable for a whole short block. Get an Echo.
Dave Crook
04-22-2004 10:11:09
 Re: Re: Stihl FS 36 Trimmer - Repair or Replace? in reply to John in MA, 08-24-2003 18:59:54
Hello,
I have an FS36 Stihl weed trimmer. I replaced the carb kit, a new plug and new gas. It started very briefly and that was it. It seems to have very high compression and even with the plug removed, it seems to have resistance when the piston is at top dead center.
I'm not sure if it is badly flooded or if there could be something else that I may have overlooked.
Help!!
Thanks,
Dave
kwright
08-25-2003 14:07:14
Hmm, I understand the FS 36 was/is made by someone other than Stihl.
What I find interesting though is that many of the various parts are embossed with "Stihl", including the engine cowling, the flywheel, and several other parts.
One would think that this wouldn't be the case if it was made by a third party - though I admit I know very little about such things.
John in MA
08-25-2003 14:58:21
 Re: Re: Re: Stihl FS 36 Trimmer - Repair or Replac in reply to kwright, 08-25-2003 14:07:14
The cowling and most of the visible parts are either made by or custom for Stihl. 75% of the machine is your basic Ryobi trimmer. The earlier FS40 was the same way.
Stihl's electric trimmer is totally Ryobi. You can see the same one in Home Depot under the Ryobi and Homelite brands.
kwright
08-24-2003 14:28:18
Thanks for the reply.
I'll probably call the dealer to get an idea of the cost of parts, but I'm pretty sure it'll be more than I believe the trimmer is worth.
stihltech
08-23-2003 18:27:44
Price out new parts and see if it is worth it to you to repair the machine. You might also check around for a used machine. I think you should look for a new machine as this model is not meant to be long lived, it is a consumer model. But I always leave it up to the customer,as they are paying the bill.
