Tool Talk Discussion Forum
Spot welding?
Bandit
08-23-2003 16:00:35
What are some tips or tricks to spot welding? Material thickness, electrode size? Thanks, I'm not to experienced yet. I have a small stick welder.... Thanks again...
SHeiserman
08-24-2003 07:22:11
 Re: Spot welding? in reply to Bandit, 08-23-2003 16:00:35
I'd say 3/32 6010 or 6011 to begin with. 3/32 diameter is muuuuch easier to control if you're not experienced. As far as amps are concerned, that depends on the person, the machine, and material to be welded. Grab some scrap and play around. I'd start with 70 amps (this is where I would start), if you blow a hole, turn it down. If it piles up or makes a big mess, turn it up or give yourself a bigger gap to fill. Cleanliness is godliness- start with a clean joint and use your grinder/wire wheel to keep it clean (at least until you're used to it). You will have to learn by trial and error, but this should help. Good luck
