Tool Talk Discussion Forum
Welding question
F14
08-21-2003 16:18:50
I'm reasonably competent with a MIG welder, but due to lack of experience, I pretty much suck at stick welding.
Unfortunately, the only welder I have available at work is an engine-driven stick welder.
I'm slowly learning about amperage vs. rod size, what rod size works best with what thickness material, etc. I can lay a pretty decent bead in a simple horizontal weld, flat or fillet.
The particular question I have at the moment is what technique works best for vertical welds? Bottom to top? Top to bottom? More or less heat? Stick out? Stick motion?
I'm the only one in the shop at the moment that will admit to knowing anything about welding, and the repair I'm doing requires some vertical fillet welds.
SCOTT BARBER
05-23-2004 02:15:30
 Re: Welding question in reply to F14, 08-21-2003 16:18:50
I bought a 110 amp arc welder off the internet.It came with no plug on it which they said it would not be shipped with one. What I need to know is which wire is ground,hot and nuetral? One is a green wire with a stripe on it. One is a creamcolor and one is blue.Hope you can help me with this problem. Thanks for your time.Scott
waynesville
09-01-2003 16:35:33
I am a certified welder.Always weld a vertical weld from bottom up unless it is just a filler.Use small circles pausing on each side to burn in.If there is a wide gap or a very strong weld is needed use three passes,one on each side and a cover pass.
BFO
08-24-2003 16:11:40
Verticle up and 7018AC worked pretty good for me way back when I just had the ac buzz box, email me if you have any problems.
F14 - Thanks, Folks
08-22-2003 15:09:41
All we have is 6013 rod in various sizes, and a straight AC (?) engine driven welder, so I fairly restricted in my choices of techique.
I did manage to get it stuck together, but it's truly ugly. The problem was made worse by the fact that the joint was open well over the recommended 2/3rds of rod diameter.
I'm beating on the boss trying to shame him into getting us a better welder...
Joel Harman
08-24-2003 05:41:32
 Re: Re: Welding question in reply to F14 - Thanks, Folks, 08-22-2003 15:09:41
If it is engine driven it is probably a DC unit.
Chris-se-ILL
08-22-2003 20:20:32
When I worked at my BIL's propane company all they had there were some odd's and end's type of rods... He wanted me to do some welding for him so I told him he would have to put out for some decent rods... I went out and bought him some 6011's / 6013's / 7014's / 7018's in various sizes.
Stick with 6011's for verticle welds... even 6013's have too much flux {JMO}. And never try 7014's for verticle!!!!! If the joint is too wide then you will have to do several passes and fill in the middle {building up either side till they join}... Make sure to knock out any slag between passes!!! Then use the grinder to clean up the globs. It takes time but it can be done.
If you are trying to finnese a new welder out of the boss..... don't get too proficiant with this welder ;-) Then offer to take the old welder off his hands for him after he gets a new one! {HA!}
Fawteen
08-23-2003 02:35:03
 Re: Re: Re: Welding question in reply to Chris-se-ILL, 08-22-2003 20:20:32
I work as a mechanic at an equipment rental place. The welder I use is a rental unit, so even if we got a good one, the ol' engine-driven Lincoln would still live under the stairs.
Not a bad unit, for what it is, just not very versatile.
Big 10-4 on the 6011, I can get the boss to spring for 5 pounds of that, I think. He's so tickled to have a backup mechanic, he's pretty good about indulging me on the small stuff.
It's getting HIS boss to spring for anything that costs over $50 that's a good trick...
BTW, I was repairing/replacing the hinges on the feed apron of a Morbark chipper. Nice unit, diesel engine, but a tad underengineered where the folding feed apron hinges to the hopper. 1" pins welded to 3/16ths sheetmetal. The sheet metal is stiffened by a rolled edge and some bends in the corners, but the weight of the apron and the vibration is a killer and everything stress cracks.
TimV
08-22-2003 15:57:45
F14: Glad to hear you got it back together (whatever "it" was....)! If you're stuck with AC, (as I am also, at least at home), use 6011. It's designed as a "fast-freeze" rod, so you won't have the weld puddle running all over creation faster than you can weld. Assuming there's nothing else wrong with the welder, you can weld some pretty good vertical beads with 6011 and AC--not the prettiest in the world, but perfectly servicable. If worst comes to worst, spend $5.00 of your own money and buy a pound of 6011 in whatever diameter would work for your next application. It's a lot cheaper than a new welder. There's a ton of great welding info online, particularly at Hobart's website--the discussion forums over there are filled with experienced welders.
Bill 52 8n
08-22-2003 11:03:30
You'll need to turn the amps down campared to running flat welds. Unless you are welding sheet metal, it is best to weld bottom to top. There are many motions you can use to weld vertical, the best one is the one that works for you. You can use a Z, J, U, or an oscilating motion. For larger rods (1/8th, 5/32) I like to use a J or U motion, smaller rods (3/32) you can use a Z or oscilating because of the less heat input. To run a J, start the rod, run it across the joint (the bead will be wider than a bead welded flat) then step it ahead of the weld pool, this gives the metal time to set, then bring the rod back down and across the joint. Pause at the sides of each weld to let it burn into the plate, and long arc when you whip out of the puddle. Once you get a good rythm going you will have decent looking beads. 6010 or 6011 is easier to run vertical, just whip the rod straight ahead of the weld pool like in welding in flat position. HTH
Bill
Chris-se-ILL
08-22-2003 06:03:01
Unlike the other two comments already voiced, I cannot make a decent verticle weld running the bead from the bottom-up!! The metal will poolup and run back down the joint building big blobs of slag....
I have done a lot of stick welding around the farm and have had to learn (self-taught) how to weld vertically and upside down. I almost always use a 6011 rod (less flux to get in the way, but more splatter), I also make several passes! I keep the rod pointed towards the weld (pointed in an upward manner on a verticle weld, since I am welding from the top-down) and I definitly try to keep the arc as short and close as possible (working the melted material with the tip of the rod). Backing away and creating a longer arc increases the amperage, thus increasing heat, and melting the material faster (probably too fast). I also move somewhat quickly down the joint and keep the amperage to the bare minimum (so as to not melt material too quickly). After a while you get used to seeing the molten metal flowing toward the rod and learn what speed to maintain to stay on the leading edge of it!
As for rod size and amperage... larger pieces of metal = larger rod (more amperage). Smaller pieces = smaller rods (less amperage). I will not attempt to tell anyone what amperage or rod to use because conditions and equipment are all different.... experience and practice are worth the effort! Keep slag cleaned away from the joint for your second and possibly third passes. wire brush between welds.
Good luck!
Dad taught me to weld, and basically told me that to learn how to weld.... you just have to experiment and burn a ton of rods (preferably on a lot of scarp metal), and remember what works and what doesn't work for you! What works for me and others, may not work for you! Seldom do any two welders have the same technique or abilities.
TimV
08-21-2003 18:04:36
F14: I'm hardly an expert, but I can bubblegum and chickenshutt most stuff I have to weld, at least long enough for something else to break... Vertical welds are best done bottom-up. I've attached a link for a previous discussion that T_bone put in a while ago--he goes into more detail, and he's twice the welder I am--at least going by his credentials.
JM
08-21-2003 17:04:53
Bottom up, I use an arc length similar to rod thickness, semi-circular motion, DC-, 60XX rod, 70XX seems to be very difficult to use for anything but easy positions.
