Hi Lee, The pressure switch could be adjustable (although it may not be) and certainly should be replaceable. Before you try to adjust it though, make SURE your storage tank is rated for some pressure at least equal to, and preferably in excess of, 125 psig and that it is in excellent physical shape. There should be an ASME label plate tackwelded somewhere on the tank that will give the maximum allowable working pressure (MAWP). If that is at least 125, then go ahead and try to adjust your pressure switch upward to no more than that if you want. The only problem that you might run into is motor overload. The capacity specs you noted seem outstanding for a 115v, 1-1/2 hp motor. Too good actually. They are more like the old Craftsman 2 hp, 230v compressor I used to have. Whenever you increase either the speed or pressure of a reciprocating air compressor, you increase the hp requirement. The hot temperature is normal. Compression of air creates high temperatures. If it runs for any length of time, the compressor and tubing running from it will be way too hot to touch. If it runs continuously for 20 minutes or so you probably could fry eggs on the head :o). Rod
