Tool Talk Discussion Forum
Antique Lincoln Welder Question
DaveInMI
08-21-2003 06:07:15
I was given a old motor driven DC welder. Plate indicates: Lincweld DC 250 MK Welder. Input-32 amp 220v, 3-phase, 3600 rpm, code# 3051, serial# A350500. My first question is how much HP for the motor? I will need a phase converter. Any other information would be appreciated.
arthur
08-21-2003 15:21:58
 Re: Antique Lincoln Welder Question in reply to DaveInMI, 08-21-2003 06:07:15
230V. 3phase generator not a welding generator.contact Lincoln for a wireing diagram how to rewire for 120/240 single phase . if its a good one maybe you could run a buss boxwith it. lincoln can tell you the engine size also. good luck
DaveInMI
08-22-2003 03:02:28
 Re: Re: Antique Lincoln Welder Question in reply to arthur , 08-21-2003 15:21:58
The motor is 3-phase. I welded on one of these in the 60's and it was old then but I liked how it worked.
Robert
08-21-2003 08:17:14
I can't give you an EXACT horsepower for your motor, but according to my "freebie" calculator, it's somewhere between 10 and 15 horsepower. A 10 hp motor is supposed to draw 28 amps at 230 volts, and a 15 hp will draw 42. That's assuming 100% load, of course. Recommended wire size (minimum) for a 10 hp. motor is 8 AWG, for a 15 hp., the minimum wire size is 6 AWG. If it were mine, I would err toward the heavier wire, just to be on the safe side. Hope this helps, and good luck!
arthur
08-22-2003 15:28:25
 Re: Re: Antique Lincoln Welder Question in reply to Robert, 08-21-2003 08:17:14
sorry i miss understood thinking the tag info.was for the generator not the motorthat driver it sounds like a 10 hp .still think it best to go to lincoln and get a wire diagram for it will help solve problems later good luck .
