Tool Talk Discussion Forum
Belarus 250as hydraulic problem
Jon
08-19-2003 18:18:21
hydraulic system was working fine when I started mowing but when I finished the lift will not pick up the mower. Disconnected 3 point and every thing looks good no damage to any parts, no leeks, but I can lift on the 3 point arm by hand while using the lift lever and get it to raise. It does not leek down once it is up. Any help on where to start?
Neal-WI
08-19-2003 20:30:07
 Re: Belarus 250as hydraulic problem in reply to Jon, 08-19-2003 18:18:21
I had the same problem. I added a quart of 30wt non detergent to the hyd system and the lift has worked ever since. I have a 220 diesel and this was the only serious problem I have had. I don't think there is a dipstick for checking for the proper level. Looking through the fill hole, it looked like it could hold more fluid, so I added a quart and that took care of the problem. Apparently I was at the low level for the system to work.
I also had the PTO slip into neutral while mowing, but I cured that with a small bungee cord to hold the lever in position.
Check through the fill opening and if it looks low, add a quart. You have nothing to loose.
These are not nimble machines like our John Deere 420, but it works great on large areas.
CR
08-20-2003 09:40:39
 Re: Re: Belarus 250as hydraulic problem in reply to Neal-WI, 08-19-2003 20:30:07
On the 250AS right in front of the fill cap for the hydraulic fluid is what look like a bolt. The dipstick is located on the end of that bolt. Kind of awkward to remove the dipstick as it is under the floorboard. Also make sure that the auxiliary hydraulic lever is centered.
HTH
CR
