Tool Talk Discussion Forum
Harbor Freight/US General air compressors
Maxx
08-19-2003 04:42:23
Has anybody had any experience with the Harbor Freight/US General air compressors? On paper, they look like a good deal, $397 for a 60 gallon, 6.5HP (I don't believe it, 230 volt, 15 amp) 13CFM at 90psi. I talked to the company that manufactures them, they are located in South Carolina. They said nothing chinese on the compressor, motors are AO SMITH, and the pump has cast iron sleeves with alluminum fins. The manufacturer told me that was better than solid cast, because of better heat dissipation. Anybody have one or have opinions? I am a little leary about dropping that amount of $$$ at Harbor Freight if it won't last.
Thanks
Roger
08-19-2003 15:33:19
 Re: Harbor Freight/US General air compressors in reply to Maxx, 08-19-2003 04:42:23
Should be a decent machine for home use. It is an Italian pump. They seem to hatch small aluminum pumps over there buy the bushel. 130 PSI is a reasonable cut-out pressure for a single stage machine. It will run cooler than a cast-iron unit, but faster and a bit noisier. Main downfall of this type of pump is the plastic air filter housing which tends to warp or crack and then fails to seal properly. As these machines often get little maintenance, they are usually left to run with the filter open and that's what kills the valves and cylinder liners. If you are at all conscientious about maintenance, it should do ok. Just don't expect to sandblast a battleship with it.
Maxx
08-20-2003 19:11:53
 Re: Re: Harbor Freight/US General air compressors in reply to Roger, 08-19-2003 15:33:19
You're exactly right, I meant to mention that the rep told me that the pump was Italian. I decided to play it safe and reliable and get a 80 gallon Ingersoll-Rand that puts out 18.1 cfm @ 90 psi from Tractor Supply Co. Thanks for the help!
Roger
08-21-2003 18:11:35
 Re: Re: Re: Harbor Freight/US General air compress in reply to Maxx, 08-20-2003 19:11:53
Most of the small IR pumps are decent. I like their small vertical twin cast iron units, the SS3 and SS5.
Maxx
08-23-2003 05:34:02
 Re: Re: Re: Re: Harbor Freight/US General air comp in reply to Roger, 08-21-2003 18:11:35
Yes, thats the one I have, SS5N5. So far it works great.
