Tool Talk Discussion Forum
Wiring 220 at the box
Kevin
08-13-2003 14:05:49
I am getting ready to install an electric water heater at the box. I have always installed 220 volt the "normal" way,ie. a double throw single pole breaker that mounts to one side of the panel. However, I seem to remember someone somewhere stating that 220 should take 110 from each side of the panel for better power distribution. Does it matter? Thanks.
Dave Wis
08-14-2003 18:14:41
 Re: Wiring 220 at the box in reply to Kevin, 08-13-2003 14:05:49
IF you use the full size breakers it won't matter where you put it in , you will get 220. However if you use the 1/2 size breakers you need to watch so you get opposite lugs on each clip of the breaker.
Kevin
08-14-2003 18:06:11
I suspected as much, thanks everyone.
paul
08-14-2003 08:01:12
It has to take 110 from each side, no other way to get 220.....
--->Paul
Bigdog
08-14-2003 09:26:38
 Re: Re: Wiring 220 at the box in reply to paul, 08-14-2003 08:01:12
Like Fawteen said, the lugs are interwoven down the panel so that every other lug is connected to one leg of the 220. So no matter where you throw the double pole breaker in the panel it will connect to both legs of the 220. When you're in a home store sometime look at an empty breaker box. A picture is worth a thousand words.
Robert
08-14-2003 05:39:49
Actually, I think the breaker is "double pole, single throw", but, as previously posted, 120 v. is taken off of each leg in the box.
Fawteen
08-13-2003 14:43:49
A double pole breaker DOES take one branch from each phase. As you go down one side of a breaker box, it alternates phases.
