Tool Talk Discussion Forum
Compressor / Tool Compatibility
Chris
08-12-2003 10:29:02
Can someone explain the following rating on a die grinder: 3 CFM; 12 CFM @ Load. I am looking for a compatible air compressor to run this tool - do I consider matching the 3 CFM with the compressor rating or the 12 CFM?
John in MA
08-12-2003 19:37:03
 Re: Compressor / Tool Compatibility in reply to Chris, 08-12-2003 10:29:02
The low would be when it's idling, the high is when you're grinding.
How long do you need to use it continuously? You can run a huge grinder on a small compressor, but you'll have to stop after ~30 seconds to let it refill. If you need it 100%, go with the 12 CFM compressor.
Rod (NH)
08-12-2003 14:40:56
Hi Chris,
I wish pneumatic tool manufacturers would be more specific and consistent in their ratings (i.e. no throttle pressure is specified and it is not clear if the cfm is referred to standard conditions, e.g. scfm). In any event, I think you should use the larger number when comparing to compressor capacity. I suspect that the 3 cfm is either referred to some throttle pressure or is an "average" consumption considering that the throttle will likely not be open continuously. If it is an average, in your case it means that the tool can be used for only 25% of the time, which is unspecified, in order to keep the consumption down to an "average" of 3 cfm. The @ load likely means the consumption when the tool is under full rated load and not spinning free. The free speed rpm and the air consumption would be greater still with no load on the tool. That's my best guess given only that information.
third party image Rod
Ben in KY
08-12-2003 11:56:44
I believe those are the MIN and MAX CFM's. I would size for the larger CFM. Or at least close to it.
