Tool Talk Discussion Forum
reconditioning aux gas tank
RonB
08-11-2003 09:39:19
I have a 50 gal capacity gas tank that rides in the bed of my PU truck. It was drained about 9 months ago and was left behind the shop. Now I plan to put it back into service. Question: How should I flush the tank to check/eliminate any rust or water condensation in the tank?
Gordon NH
09-02-2003 17:55:08
 Re: reconditioning aux gas tank in reply to RonB, 08-11-2003 09:39:19
Ron: Kind of depends on the condition of the tank. Since it's a 50 gallon, you should be able to see inside of most of it with a flashlight. The auto restoration suppliers make a "sealer" for sloshing around and "refinishing" the inside of the tank. If your tank is in pretty good shape and just a little moist, tank it up and use some dry gas. If the tank is real nasty and scaly, I've heard if tumbling hardware or stones in it to break up the rust, but I'm not sure if I like that idea or not. I suppose it would work and then you'd have to wash it out with maybe kerosene (higher flash point than gas). Be careful. Good luck.
Gordon NH
