Tool Talk Discussion Forum
Welding current
Slowpoke
08-11-2003 00:33:00
I was just thinking, if one were to place an AC clamp-on ampmeter on the ground cable of a mig welder, would the reading be accurate?
ed
08-11-2003 09:58:55
 Re: Welding current in reply to Slowpoke, 08-11-2003 00:33:00
1.) do you have a ampmeter big enough.
2.) how would you connect it up
3.) what difference will it make if the number painted on the side of the welder is accurate or not? If you do any amount of welding you'll get to know your welder and when to turn it up or down. if you don't your not going to weld very well untill you do. You can teach someone to weld in a couple of minuted but it takes hours of practive to really learn
1. Ed, yes
08-11-2003 18:44:12
 Re: Re: Welding current in reply to ed, 08-11-2003 09:58:55
I have a meter that reads to 200 amps.
2. It opens up and clamps around a wire like your thumb and forefinger together.
3. Just for curiosity. And to stir up trouble here on the forum.
Slowpoke
Greg S
08-12-2003 08:11:44
 Re: Re: Re: Welding current in reply to 1. Ed, yes, 08-11-2003 18:44:12
Measuring welding voltages and currents are common in the welding industry. Any welding that is done to a certifiable standard must have these parameters measured to produce a "certified" weld. When the "joint weld procedure" is first established the voltage and amperage are measured, this information is then used to produce a range of settings that would enable a welder to produce a satisfactory weld using these settings. A clamp-on ammeter (either ac or dc depending on the power source) is put around the welding lead to measure current. The voltage is measured between the lead and the workpiece. Sure the average hobby welder or repair shop is not going to go to this extreme, but on the other hand how comfortable would you be going up in a 100 story elevator shaft that was welded by some guy using a by-guess and by-God welding setting??
JMHO.
Slowpoke
08-13-2003 00:34:06
 Re: Re: Re: Re: Welding current in reply to Greg S, 08-12-2003 08:11:44
Greg..Thanks for the behind the scene tour.
Chris-se-ILL
08-11-2003 06:27:46
Why would the amperage reading matter?
I have not used MIG, just "stick" welders.
With a stick, if it is splattering way too much and melting the metal too fast... crank it down!
If it won't strike an arc very easily, the rod sticks to the work when striking the arc, and the metal won't flow well... turn it up!
After burning 20 or 40 pounds of rods over a couple of years, a person can set the amperage fairly close before they even strike an arc.
(my .02 worth)
MarkB
08-11-2003 03:44:23
First, MIG welders are DC, not AC.
Second, weld current is not particularly constant, so most meters aren't going to measure it very well.
Third, how were you going to read the meter with your welding helmet on? ;)
If I was going to instrument a welder, I suppose the best way would be to run the current through a shunt and monitor it with a storage oscilloscope. That way you could run a bead, then go and look at how much current you used from start to finish. A second choice would be a shunt and a digital multimeter with "peak reading" capability.
GPWT
08-12-2003 10:48:13
 Re: Re: Welding current in reply to MarkB, 08-11-2003 03:44:23
You are right. We build weld machines and always use shunts for weld current measurement, both built into the machine and with an o'scope for field measurement.
Mark, the answer to the
08-11-2003 19:01:07
third question is to have some one else read it, use a video camera, or set up a shunt and use my peak hold dvom.
BYW, a neighbor has an HP 1018A(?) scope for sale. He wants $15 for it, no leads. I think it's a dual trace. Is it a steal or a boat anchor in your opinion?
Slowpoke
MarkB
08-12-2003 18:49:15
 Re: Re: Re: Welding current in reply to Mark, the answer to the , 08-11-2003 19:01:07
Slowpoke, I'm not familiar with that particular scope, but any oscilloscope in working condition is worth 15 bucks.
Dual trace itself is not that important, but dual trace scopes usually have "add-invert" capability, which is good. "Add-invert" means you can invert the B input and then add A + B, so can make differential voltage measurements. Good for shunts and noise elimination.
Any modern scope will have triggered sweep, which is also an important feature.
The last thing to look for in an oscilloscope is storage. It is rare in analog scopes, but pretty much standard in the newer digital scopes.
If you intend to make high-voltage (> 100V p-p) measurements, you'll need a pair of X10 probes. They'll set you back more than your friend's scope.
BTW, the hottest scope on the market today is the Fluke "ScopeMeter", which is a full-blown digital storage oscilloscope in a package about twice the size of a DMM.
mike
08-11-2003 14:52:38
Mark, FYI most MIG welders can be AC or DC voltage. It depends as to wether you are using wire and gass, or just flux core wire. there are metal plates that change the voltages.
Bill 52 8n
08-12-2003 18:33:59
 Re: Re: Re: Welding current in reply to mike, 08-11-2003 14:52:38
I have to agree with mark. Mig is reverse polarity. Flux core can be straight or reverse depending on the wire and if it is shielded or not. I have never seen AC Mig
Bill
MarkB
08-11-2003 18:51:54
Mike,
I've yet to see an AC MIG welder, although I suppose they do exist. Are you sure you don't mean forward and reverse polarity?
At any rate, I don't know why anyone would instrument the weld current in the first place.
