Tool Talk Discussion Forum
Any one ever seen a
JoeK
08-10-2003 15:02:49
Top motor electric weed trimmer?Built like a gas trimmer.Seems to me that w/a shoulder strap like the gas trimmers have this would make more sense than having the motor and vents down in the debris field like they are on electrics.I don't need a gas rig and dislike the noise and fuel mixing,but the corded electrics I've tried are"junk" mainly because of dirt/crud etc accumulation and lightweight low quality heads used,along w/light line.With a larger balanced motor you should be able to run the same head types and line the gas units use.
Roe Lane
08-23-2003 17:32:12
 Re: Any one ever seen a in reply to JoeK, 08-10-2003 15:02:49
Joe K. Homelite made two trimmers with the motor at the top the ST 30 and the ST 70, that I know of as I have the parts books on them. They were very simply made and look as if they would be well balanced..They also made an ST-80 which was a gas trimmer with the motor at the bottom. (Bet this was a mess). All are Probably no longer made..Roe
Harvey Schoenman
12-26-2005 13:45:06
 Re: Re: Any one ever seen a in reply to Roe Lane, 08-23-2003 17:32:12
Roe Lane, or anyone else. I have a Homelite ST-70 electric string trimmer. The string cutter/guard at the bottom is broken and the string hits it and wraps around the shart. I could use the parts book for this trimmer if you still have it.
Randy Martinson
11-13-2003 22:35:30
I have a ST 80 at home here and am currently rebuilding it. It has been in storage for the last couple of years and will be working as best as it can when done. Yes they are a lightweight and balanced trimmer. Yes they are right in the thick of all the dirt, dust and etc. being down there. Parts are still available for it. It was bought and made in 1983, so even after 20 years, it is still a neat machine. Any questions...let me know.
John in MA--they're all t
08-11-2003 16:27:16
The only top-motor trimmer I'm aware of right now is the one the guys are talking about. That's right, it's the same unit. Ryobi makes them. They recently bought Homelite and they also make the FS36 and the electric for Stihl.
ryobi
08-11-2003 14:32:07
I have the curved shaft riobi like the one above and I love it. When you grab it by the handle, it balances perfectly level. However, it does feel as heavy or heavier than a homelite gas trimmer that I used before.
JoeK..Thanx fellers
08-11-2003 06:49:11
Gives me some options to check out,thanx for the assist.
Trevor
08-11-2003 06:09:33
Joe,
last year when I bought my Stihl I thought I saw a Stihl electric trimmer with the motor mounted like a gas unit. I don't know if it had a strap on not.
Check with your Stihl dealer.
Trevor
08-11-2003 06:12:10
 Re: Re: Any one ever seen a in reply to Trevor, 08-11-2003 06:09:33
Joe,
Just checked the Stihl web site. I was right, it is called the FSE 60 I think. Check the link.
rhudson
08-10-2003 21:33:29
i had one years ago. i think it had the homelite name on it, although i don't know who made it. it lasted year after year until finaly my wife stepped on the shaft and bent it. it was really great for a small yard.
Jon H
08-10-2003 18:05:59
I think you have a great idea there. Apparently so does Ryobi. A web search turned up the Ryobi model 137R which is an electric trimmer with a top mounted motor just like what you suggested.
I will try to link you to the site.
Jon H
08-10-2003 18:23:41
 Re: Re: Any one ever seen a in reply to Jon H, 08-10-2003 18:05:59
They also make a curved shaft model which is usually cheaper if you have no need to get under fences etc.
