Hi Jack, I think you made an excellent choice is saws. After many years of old McCullochs, I got a 026P about three years ago. I love it. I believe it is the older version of the MS260. Great power to weight ratio. At least for me that edged it out over a similar Husky, which was a close second. It came with an 18" bar and 0.325 pitch chain. The very first thing I did was to replace the bar with a 16" one and to change to 0.375 pitch chain. I see little advantage for a longer than necessary bar. It simply adds to the weight and tends to get in the way more during limbing. If the 16" one will handle the vast majority of your cutting, I would recommend going with it. If, in the future, you have an occasional need for a longer bar, it is a simple thing to add. And if your needs change to bigger stuff most of the time (that a 16" won't handle), you probably ought to be thinking about a larger saw anyway instead of just a longer bar. I decided on the 0.375 chain because I already had quite a bit of it in bulk and did want to stock up on another chain size. The saw has no power problem at all running the larger chain in any wood. Rod
