Flexible Shaft tool
Andy Roeper
06-01-2000 06:19:40
After about 30 years of good use, my flexible shaft has flexxed its last flex. 'Started looking around and seems to be a hard thing to find. Help!
One end connected to a small old motor - probably about 1/4 to 1/3 horse via a set-screw coupling. The other end was about 1 1/2" diameter hand grip terminating in a threaded shaft about 3/8" fine thread and inch or two long. Great tool for cleaning up equipment with a wire brush like you would use on a bench grinder. Inside of the nearly 4 foot long shaft was multiple layers of coiled spring wire - kind of like a speedometer cable on steroids. Nobody around here has any ideas and looking on the net the only things I find are boiler tube cleaners - which are long (that's OK) but have exposed shafts and specialized ends. This thing was way more robust then a dremel or foredom cable (you could stall the motor before the shaft would coil up).
JerryB
06-05-2000 15:53:49
 Re: Flexible Shaft tool in reply to Andy Roeper, 06-01-2000 06:19:40
Andy:
Try McMaster-Carr Supply Co. either at www.mcmaster.com, or 562-695-2323. Their catalog is on the web site. Just have to have some patience to find things. They are real helpful on the phone. Will take credit cards & usually ship same day.
In their paper catalog #106, they show several replacement flexible shafts for motor driven tools from the 1/10hp Foredoms up to 1/2hp generics on page 2324 & 2325.
Hope this helps,
JerryB
Jim Kasten
06-04-2000 18:42:11
Try contacting B.W. Elliott Mfg. co. in Binghamton Ny Their phone number is (607) - 772-0404. They make Flexible shafting. They may know exactly where you could get an item like that.
They bought out the division of the company that I work for " Stow mfg" I remember we used to make The shaft assembly that you are talking about.
Gregg
06-04-2000 16:46:14
I just bought a Sthil weed cutter that has a flex cable like you describe, you may be able to adapt one to work, the one in mine is about 1\4 inch diameter and 5' or so, good luck
