Tool Talk Discussion Forum
what is your most used tool?
howster mighty
08-08-2003 18:39:24
Outside of my plier or pocketknife I think it is my wire brush mounted on an old sickle grinder. From buffing points to cleaning up old bolts I don't know how I could get along without it.
S.L.
08-21-2003 16:40:20
 Re: what is your most used tool? in reply to howster mighty fine, 08-08-2003 18:39:24
My makita angle grinder. Its a cutter, shaper, cleaner. Cant live without it.
big fred
08-11-2003 14:10:11
my ion phase diplexer with the inverse coaxial resonator. If that don't fix it, I got a big honkin' hammer I hits it with, then I open a beer.
Glenn-WV
08-10-2003 20:09:12
Pocketknife, bar none.
Indydirtfarmer
08-10-2003 05:07:05
I've got 8 kids, so my most used tool is....I know what you think I,m going to say.... My cell phone.
John C. (ca)
08-10-2003 00:53:01
Duct Tape and a Hammer
If it moves and it shouldn't-- Duct tape it.
If it doesn't move and it should ----Hit it.
Have a good day
Scottey841
08-09-2003 22:08:50
Nobody mentioned the internet or their cell phone! As for real tool it has to be cordless drill.
treefarmer
08-10-2003 09:15:10
 Re: Re: what is your most used tool? in reply to Scottey841, 08-09-2003 22:08:50
tape measure
Chris-se-ILL
08-09-2003 06:21:07
Really tough to answer that Question!!!
I would have to say my "BRAIN!"
My brain is what I use the most on the farm and in most things I do. Whether visualizing, analyzing, contemplating, imagining, calculating, organizing, or scrutinizing... I have to rely on it more than my hands and feet. And without it's usage... I would not have the skills in my hands to machine, weld, build, deconstruct, repair, and do what is required on any job.
Now, I know that is not what you were asking about (and I know it is a given... for any of us) so I will say that my most used tools would be pocket knives (I usually carry several for different jobs... i.e. good knife with razor sharp blade, old knife for prying and digging). I also carry a "Gerber" (brand) multi-tool plier, plus a small cresent wrench in my pants pockets. They are the first things that I reach for when I need a small handtool. As for power tools... it is a toss up between the stationary 5hp grinder/wire wheel, the drill press, metal chop saw, the torch (fire-wrench), and the metal lathe.
Richard
08-09-2003 06:18:58
Beer Coozie
Rick
08-09-2003 06:18:32
My mobile tool work bench I built is number ONE. Second is air impact
TimV
08-09-2003 05:32:06
Interesting question (to say nothing of some interesting answers....) but I'd have to say it's my cordless drill. Sure does spoil you! It's a screwdriver, ratchet, drill, grinder, cut-off wheel (and occasionally hammer, paperweight, and plumb bob) all in one.
JD790
08-08-2003 21:49:40
9/16 inch wrench>
Jacob
08-08-2003 21:43:51
My BRAIN !! heh heh.
I couldn't get anything done without it.
John in MA
08-08-2003 20:52:04
For power tools, either my cordless drill or angle grinder. For mechanial, probably the vise. Something's always getting clamped in there and ruined. :)
Hopefully the drill press is rise to the top now that I'm done restoring it...
John A
08-08-2003 20:30:29
Howster mighty fine, Like you said other than my pocketknofe and pliers My most important tool Is my PICKUP! All projects start or end around it.
Enough said!!
John A.
ray
08-08-2003 19:44:15
grease gun, screw driver, adjustable wrench, fence pliers, hammer & bottle opener
wdTom
08-08-2003 18:46:20
Hammer, vicegrips, welder, lathe, milling machine, screwdrivers, wrenches. Tough question. Wire wheel, belt sander? I don't know.
Slowpoke
08-10-2003 23:54:52
 Re: Re: what is your most used tool? in reply to wdTom, 08-08-2003 18:46:20
Angle grinder with a wire cup brush.
zippy
08-08-2003 22:18:04
my handie dandid vibrating butt plug
wdTom
08-09-2003 18:11:42
 Re: Re: Re: what is your most used tool? in reply to zippy, 08-08-2003 22:18:04
Well, you are lucky if you have one that vibrates!
