Tool Talk Discussion Forum
Truck Tires
KS
08-08-2003 18:32:20
One of my favorite tools is my brothers truck.
I borrow it to haul old tractors home.
The only issue is tire wear, it seems to go through a set of tires in about 22,000 miles.
It's a 3/4 ton diesel 4x4, pulling a gooseneck. We are getting ready to put on the third set. What brand tires are you guys running and how many miles do you get from a set?
Brokenwrench
08-11-2003 14:55:14
 Re: Truck Tires in reply to KS, 08-08-2003 18:32:20
I have the same problem with my dually. I used to rotate them every six thousand miles. All that did was wear six tires out in 30,000 miles. Now I just grin and bear it and replace the steering tires every 25,000 miles.I've tried Michelins,Goodyears, and now run Coopers, they all lasted about 25,000. The rears last 48-50,000. This is a work truck, usually overloaded,and it pulls a trailer alot.
Trevor
08-11-2003 09:46:00
Well I have never had a set of Coopers but I swear by BFGoodrich. I have had numberous sets on different trucks and SUVs and they last great, get awesome traction, handle well and don't have belt and vibration problems.
I will say that my most HATED tire is Goodyear. I don't know when they had a Good year but it wasn't recently! I have had a few sets of goodyears and have had nothing but problems with them. The most recent set was on my truck when I bought it and the belts and insides of these tires were wrecked and there was still about 20,000 km left in tread on them. I always kept the pressure up and never ran them flat or hit large bumps with them. I hate Goodyear!!!
ScottT
08-10-2003 20:23:38
I have a similar truck and got about 60,000 miles on the Firestone Steeltex's it came with (could have gone more but winter was coming). I have Bridgestones now, almost 30,000 on them, I should get another 20K anyway. They are a softer compound than the Firestones, but they definitely have better grip in the snow.
If you drive hard (acceleration and braking) they will wear out faster...
Scott
Jim B.
08-10-2003 19:25:50
Cooper--- Hands down best I've ever run. About $85-105.00 depending on size. Best mileage is 88000 and still going on one truck, 35000 and 11/32 tread left on another. Inflate to max and use wide enough rims. Not too good for hi speed though- tend to need balancing alot. (Above 70-75 mph). I slowed down.
Dang, I must be gettin old. Good luck.
Mike
08-10-2003 17:18:11
Cooper.
Good tires,good price, good dealer(he'll repair a puncture while you wait at no charge)
Ol Chief
08-09-2003 20:57:41
I had not heard of Fisk tires in 25 years however they seem to be a favorite with some of the reputable usedtruck dealers in Houston,Tx.area.I purchased an 1995 F350 four door pickup w/111,000 miles on the clock.It came with a full set of new Fisk tires.I just changed two back tires when tread was down to 1/8" having gone 57,674 miles.Fronts still have probably 5-6,000 miles left to go before 1/8"of tread remains.About half of milage was dual hwg.other half high crown state roads in hill country.Full loaded with around 4,000 lb. on trailer 25 to 30% of miles,otherwise usually 450 -500 lb on truck. Belive me,I am staying with Fisk for replacements.I had two alignment checks and one rotation on those tires.
Ol CHIEF
08-12-2003 20:34:59
 Re: Re: Truck Tires in reply to Ol Chief, 08-09-2003 20:57:41
Reply to Toms inquiry.Tom If you are in Texas check out Discount Tire Company.I never use any other because their service is best I have found.They stock Fisk.
Tom
08-13-2003 05:27:51
 Re: Re: Re: Truck Tires in reply to Ol CHIEF, 08-12-2003 20:34:59
Thanks to Ol-chief, I am in TX and our town has a Discount Tire. Will check.
Tom
08-10-2003 15:21:38
Hey Ol Chief, where do you get Fisk tires?? What dealers carry them?? Thanks
RayP(MI)
08-09-2003 17:40:55
Have you eliminated causes of excessive wear like allingment, balance, proper brake balance, inflation, loading, etc.? What kind of surfaces are you driving on? Lots of high speeds? Are you driving it hard, or taking it easy? Are the tires you're using rated for the services you're asking of them? There are a lot of variables which can effect tire wear. Find a good, honest, knowledgable tire dealer, and discuss your concerns with him.
Chris-se-ILL
08-09-2003 06:36:19
(Just my 2 cents worth...) Cooper and Michelin seem to last the longest for heavy hauling road usage!
If "I" were going to invest in some expensive, top-of-the-line tires, I would also invest in a "4-wheel alignment" (all axles) from a very reputable garage! Then check the alignment EVERY year, usually in the spring (maybe even twice a year on a 4X4)! Also, I'd make a schedule (by miles traveled) to rotate the tires at regular intervals, and keep it in the glove box!
fred kobs
08-09-2003 03:07:37
Hi, KS. There is a treadwear rating on the sidewall of all tires. If I remember right the higher the # the harder the rubber compound. It's a 3digit # clear down by the bead. I personally like Cooper tires. I can't remember the# but they seem to be a good all-around tire. They wear good and they clean-out nice in snow-mud etc and they don't howl on pavement. Just my 2c worth.
CNKS
08-09-2003 13:27:16
 Re: Re: Truck Tires in reply to fred kobs, 08-09-2003 03:07:37
Treadwear ratings are only on P-metric tires, tires with the LT designation aren't rated, so you have to buy quality tires and hope for the best.
kyhayman
08-08-2003 18:36:02
Michilan 245 70R16, LT, highway tread 45,000 miles; Courser AT's in the same size about 30,000.
howster mighty fine
08-08-2003 18:34:42
i got 60000 miles out of my OEM tires and we know they are not "top of the line"
