Tool Talk Discussion Forum
valve stem hole size
teadave
08-07-2003 18:35:09
after a run in with calcium leaking and rusting a hole in my rim, i need to drill a new hole in my rim. anyone know what size i should drill? thanks teadave
(by the way, it's 11.2-28 if that matters)
Slowpoke
08-10-2003 01:03:55
 Re: valve stem hole size in reply to teadave, 08-07-2003 18:35:09
I have the following numbers which are for car and light truck tubless rims:
Small rim hole: .453"
Large rim hole: .625"
You can compare the good tractor rim valve with valves on your car /pickup to see if it is the same size. If you have some old valve stems around, check those for the two different sizes. For tube type, measure the good hole with a dial caliper.
javad jafari
09-11-2003 02:01:15
 Re: Re: valve stem hole size in reply to Slowpoke, 08-10-2003 01:03:55
dear sir or madam
our company needs 500/000 tubless valves at tr414 size and about this amount at tr418 size.
withe spcial mark p on it.
would please send us your prices about these pieses.
your faith fully.
m.piran
top .manager
tele/fax : 6510833
E_mail:[email protected] FACTORY: NO 15 � GOLGON INDUSTERIAL CITY � SHAHROAD � OLD KARAG ROAD � TEHRAN IRAN TEL:0098214449002
OFFICE: NO 49 FIRST FLOOR SECTION 1 HABIBOLA AVE. SATARKHAN ST. TEHRAN IRAN
TEL: 0098216510883
here, try this
08-08-2003 18:32:22
just measure the size of the valve stem. it wants to fit snug where the thumb nut threads down.
