As was listed in this thread... Link This site has knurling tools and kits that are useful in knurling valve guides. I used to operate an automotive machine shop in the late '70's and have knurled many, many, many valve guides! There are a lot of DO's and DON'T's to knurling. For me to give a crash course on the subject, may not do justice to you or the job. If you have not knurled a guide before... don't practice on a head that you want to save/keep/use!!!!! ! Problems that you may incur... *The guide may be so absolutely worn out, that the knurling is a waste of time (not effective) and a waste of money spent by you on the job. {Question; How do YOU determine if the guide is salvagable by knurling it... if you have not had experience in knurling?} *If the guide is not worn enough and you try to knurle it... you CAN BREAK THE TOOL OFF IN THE GUIDE (at which point you then have a boat anchor)!!!!! You MUST use plenty of lubricant (best lube is one that "is made" for the tool and job) in the knurling process! Not just any lube will work! *Knurling requires a lot of torque to "FORCE" a tool to displace the metal inside the guide. You may not be able to complete the job (by hand) without the use of a gear-reduction driven drill (with a proper bit attachment). Also a drill style driver keeps the knurling tool moving in the guide.... sometimes, if you stop the forward turning motion of a knurling tool... it seems impossible to start it turning again {at which point, you break it off in the hole... and that is not good! :O } *Most knurling tools require the use of a "burnishing tool" to resize the guide to the proper valve stem diameter AFTER knurling! A knurling tool WILL NOT SIZE a guide to the proper diameter...!!! It only reduces a worn guide to a "smaller size" ...not THE proper size! *Guide replacement (as opposed to knurling) is a more permanant repair and will last much longer (knurling is/was a cheap substitute for repairing a worn guide! *It may be to your benefit to have a qualified automotive machine shop do the job for you! Or better yet... have them replace the guides for you! *The price of the tools (and fixing your mistakes) may (probably would) outweigh the cost of just having a qualified machine shop do it for you! (I am very reluctant to recommend anyone doing their own knurling job if they are not an automotive machinist!) Good luck if you decide to go ahead with this endeavor!!! You will need lots of luck!!! Chris-se-ILL
