Hi Chris, I have a Hypertherm model Powermax 350. It's a 25 amp output machine that is rated at 1/4" "recommended" capacity. It works well at 1/4" steel with a small amount of slag that is easily removed. At 1/8" and less, the cut is excellent with no slag. Beware overstated claims on cut capacity. My machine is rated at a "severance" capacity of 1/2", twice the "recommended" capacity. I would NEVER use it for that thickness. It would take too long to clean up the kerf afterwards. This size machine is typically around $1000-$1100 and is perfect, IMO, for stuff 1/4" and less. Anything thicker and you should move up in capacity (and cost). Unless you are a fabricator doing a LOT or work with steel over 1/4", the significant additional cost is not worth it. That is in the area where an oxy/acet or oxy/fuel gas torch is more cost effective and perfectly acceptable for the intermittent user. Don't worry about consumables. Tips are cheap and you probably will not go through a lot. After 3 years of intermittent use, I still have not needed to replace the original tip. No need too. I suspect that Lincoln is comparable to my Hypertherm. Go for it. You will not regret it. Rod
