Tool Talk Discussion Forum
1 and up drill bits?
Sam
08-07-2003 01:24:26
Anybody know where I can get hss twist drill bits larger than 1"? Prefferably with the shank necked down to 5/8 or 1/2". Really looking for a 1 7/16" bit, but after 2 hours of googling, no luck yet.
snitkawl
08-08-2003 02:44:11
 Re: 1 and up drill bits? in reply to Sam, 08-07-2003 01:24:26
Check with TBone, he probably knows how you can make your own!
Bus Driver
08-07-2003 16:50:18
Wholesale Tool may have what you need. But confirm that they have in stock before ordering. Their stock keeps on dwindling. I had to make a 2" hole in 1" thick steel. Drilled 1/4" hole at the center of the proposed big hole. Used hole saw to lightly scribe the perimeter of the larger hole. Center punched several holes around that perimeter. Drilled 1/4" holes just touching the outside of the scribed area. Then cut with hole saw, half depth from each side of the 1" piece. The 1/4" holes around the perimeter provide a place for the chips to fall through and the hole saw cuts much better. Need I say that this process ain't fast!
Richard Fazio
08-07-2003 15:28:00
Sam, what are you trying to drill? With holes that size on thinner stuff I use hole saws all the time. You can cut 1/4" steel pretty easy with a hole saw. much thicker than that your probably going to need a drill.
John A
08-07-2003 11:28:10
Sam, W.W.Granger. They have a good selection that are 1 in. ans over.
There probably is one close to you.
Good Luck,
John A.
markct
08-07-2003 08:29:38
well MSC, mcmaster, or most any industrial supply house could get ya one. i hope you arnt planning to use this in a half inch portable drill, it will be hard to do and most likely wreck the bit. drilling holes that bug takes slow rpms, a rigid machine, either a drill press or milling machine. what is it you are gona drill, a bit that big will not drill well in matterial under about 3/4 of an inch thick. if its not too thick a hole saw is a better choice, or a corebit works nicely too but a bit expensive to buy
evielboweviel
08-07-2003 07:49:03
ENCO
www.use-enco.com
1-800-use-enco
1-7/16" 15.99
dosn't say if american made or not, however drill sets are avaible either imported or american made. good source for tooling good luck
Dave (WA)
08-07-2003 07:40:00
Check ebay. I just bought a new 1-7/16" Silver Deming style with 1/2" shank for $12.Made in USA.
deadeye
08-07-2003 02:07:41
Try McMaster-carr.com
TimV
08-07-2003 05:22:28
 Re: Re: 1 and up drill bits? in reply to deadeye, 08-07-2003 02:07:41
It's www.mcmaster.com They've got them, but you're going to pay $75. Still, they're my first place to look for pretty much anything that falls into the "weird hardware" category!
