Tool Talk Discussion Forum
Tim B - Wiring problems
Trevor
08-05-2003 08:19:57
Tim,
I read your post down below and it gets kind of confusing. From what I see you have got it mainly figured out but the 63 V from Neutral to ground is kind of concerning.
You should make sure that the neural in your camper is grounded to the ground conductor coming from the generator and I would suggest that you ground your camper to earth via a metal rod or something when you are using your generator. If you don't ground the camper you could end up with the frame of the camper having voltage to earth and you, or someone you love, getting a serious shock when touching the camper.
Let us know what your final solution was.
