Tool Talk Discussion Forum
Test fuel gauge and sending unit
Dick
08-05-2003 08:15:44
How do I test the fuel gauge and sending unit on outboard motor to see which is faulty?
Thanks
GG
08-05-2003 19:26:21
 Re: Test fuel gauge and sending unit in reply to Dick, 08-05-2003 08:15:44
Most all these type gauges work by the amount of "ground" that is available through the sending unit. The way I have always checked this type system is to ground the wire that runs from the sending unit to the gauge. The needle of the gauge should swing to "full". If the gauge goes to full, and you know you have voltage to the gauge, the sending unit is most likely bad.--Hope this helps---
