Tool Talk Discussion Forum
LeRoi dresser air compressor
John carter
08-02-2003 20:44:40
i just got a LeRoi dresser air compressor it is around an early 70's model, it has an international 4cyc gas engine in it, i think it is a gm v8 with only half the block in use but i am trying to find out the firing order. someone had took out the distributor and wire's and i can't find a firing order on the intake?
Roger
08-03-2003 12:17:21
 Re: LeRoi dresser air compressor in reply to John carter, 08-02-2003 20:44:40
I think this is what you need.
john
08-03-2003 19:59:33
 Re: Re: LeRoi dresser air compressor in reply to Roger, 08-03-2003 12:17:21
thanks, roger i do think that is what it is and the info i need.
Roger
08-02-2003 22:14:54
I don't think it is a GM engine. It was also used in the Scout as both a 4cyl and an 8 cyl. Anyone with a 4 cyl Scount on the board?
