Tool Talk Discussion Forum
String trimmers
Pitch
07-31-2003 02:40:54
Does anyone here own a stihl trimmer? I am getting tired of having to buy a new one every 3 to 4 years. Seems any brand I buy works fine for a couple of years but when it needs work or parts I am told that the model has been discountinued parts are no longer available or that I could by a new one for less than the repairs. I found that weedeater,echo, poulan,the current crafstman,and husqvarna are all made by electrolux. The last three I've had have been either weedeater or poulan.
So out of frustration I have decided to go for a quality professional model. Anyone have any experience with Stihl good or bad? Also how much should I expect a dealer to discount of the steep MSRP?
Bernhard
08-03-2003 03:03:37
 Re: String trimmers in reply to Pitch, 07-31-2003 02:40:54
We have a FS 400 for heavier work and also a FS 85 and we�re very satisfied with them. Before that we used a small Solo. Also not bad.
Bernhard, Derichsweiler, Germany
Weed Hater
08-11-2003 23:37:37
 Re: Re: String trimmers in reply to Bernhard, 08-03-2003 03:03:37
I have had a few stihls over the years and liked them. Echo is also pretty good. The main toop brand trimmers that cost around $300 or more all are good machines. Have you seen the new Super Weed Cutter attachment for straight shaft trimmers?
pjw
08-01-2003 06:06:07
My stihl is 10+ years and still going strong. I live in the country in a hilly area where it is too dangerous in places to mow with a tractor or lawn mower so the trimmer gets a workout. It is not unusually for me to run 3-4 tanks of gas through the machine a week. Owned a Stihl saw also both have been great.
NCJohn
08-01-2003 05:52:30
I bought a Shindaiwa T-230 about five years ago. Shindaiwas are used by most professional landscape maintenance outfits in my area. It has been troublefree and very smooth and powerful. My neighbor has a Stihl that has held up well but he rarely uses it. I just think the Stihls don't sound very good, but that's just me.
Richard
08-01-2003 04:01:10
I know you asked about Stihl, My neighbor and I went out and bought two troy builts. He bought the 4 stoke and I bought the large two stroke. Both these critters start easy and cut the heck out of weeds and grass. I use mine to keep fences clean on 20 acres then around the house as well. We will see how they hold up, I guess they are about a year old..
rip2r
08-02-2003 01:57:53
 Re: Re: String trimmers in reply to Richard, 08-01-2003 04:01:10
Would appreciate a followup. The "large 2-stroke" is probably the 31cc ryobi engine which works well for awhile. There are issues about this engine also ,is this the same engine they went to 4-cycle with?
MarkB
08-01-2003 03:31:13
I've been using a Stihl FS85 for several years now and it is rock solid. If you're just trimming grass, this trimmer is overkill because it's on the heavy side. On the other hand, if you need to cut brush you need a trimmer with a solid shaft (such as the FS85). Pretty much all of the cheaper trimmers (including the low-end Stihls) use flexible shafts. This is true for straight-shaft trimmers as well as ones with curved shafts.
I routinely cut heavy brush and saplings with this trimmer. It's gone for about five years with no major repairs.
Stihl dealers are notoriously unwilling to discount their products.
hay
08-01-2003 03:21:06
i have a stihl fs80 and it gave me all kinds of trouble for almost two years. the starter head was constantly breaking. finally i got the local dealer to replace the whole starter head and it works great now! not a bit of trouble and starts everytime almost effortlessly now. sometimes, it's not the brand, it's the small problems that need to be fixed and finding a dealer to work with you on it.
John A (TX)
07-31-2003 21:06:04
My Echo's been good for close to ten years now. As someone else suggested, though, buy the "pro" models sold in the small engine shops rather than at discount stores. More expensive but built better.
YMMV, FWIW etc etc
~ja
Bill 52 8n
07-31-2003 18:44:39
We use REDMAX for our business, very light, very powerful. I've been told shindowa'a are good too.
Bill
Tim
07-31-2003 09:42:48
I've used the entry level Stihl (mine's a FS36) for about 12 years on my 2 acre lawn. Mostly just grass, but occasionally golden rod and heavier weeds. I still works fine and have never had a problem with it. So if you plan to only trim grass, don't ignore the lower priced models. Whatever the current model is costs about $129, with some kind of rebate. Be sure to drain the tank each fall - carb failure due to gas going bad is the leading cause of early death according to my dealer.
Tim
TC
07-31-2003 08:58:30
Echo is another brand to take a look at. Not the echo trimmers you find sometimes at sears, but the better ones that you'll find in a small engine or chainsaw shop.
I have no experience with Stihl trimmers, would imagine they're good though. The echo we have is a little one that's cut brush/grass for 15 years without having any work done.
Mac
07-31-2003 06:07:54
Have had 2 stihl's, going on 15 years. A new plug once in a while and thats it. I like single line spools and seems you cant get these replacements for stihl any longer. They went to 2 string. Have heard echo makes nice(easy start) machines also. Fact is stihl dealer claims they are as good as stihl. Maybe they make echo, who knows?
Trevor
08-01-2003 05:32:34
 Re: Re: String trimmers in reply to Mac, 07-31-2003 06:07:54
Mac,
Why do you like single line trimmers? I have always thought that double lines were better but I have no real reason behind it. I have never heard someone say they prefer one over the other.
Just curious.
Mac
08-01-2003 05:53:57
 Re: Re: Re: String trimmers in reply to Trevor, 08-01-2003 05:32:34
Trevor, I have had better luck with the single string around chain link fences, Just seems to work better. I compared the different spools and the single just seems better for me.
Jerry
08-01-2003 06:43:35
 Re: Re: Re: Re: String trimmers in reply to Mac, 08-01-2003 05:53:57
I prefer single line also. I think the double line just uses up string twice as fast. But you can just use one hole on your double line spool and wind it up like a single line. thats what I do.
Trevor
08-01-2003 08:16:29
 Re: Re: Re: Re: Re: String trimmers in reply to Jerry, 08-01-2003 06:43:35
Thanks guys,
I have a lot of chain link around my property so I will try the one string thing and see what I think.
Talk to you later
Nolan
07-31-2003 05:49:01
Another satisfied Stihl owner who's gone through exactly what you're in now with brands like Weedeater.
Philip
07-31-2003 05:46:28
I own a 6 year old Stihl GS75 string trimmer. Very satisfied with performance. Philip.
Trevor
07-31-2003 05:27:12
Well my father has owned a Stihl trimmer for about 14 yrs and has had only one repair on the gear hosing at the end of the shaft I believe. He uses it to trim around his house and the farm as well as using it in his maple syrup operation to cut brush around his lines and where he is cutting wood. He can take down a small tree up to 2-3" in diameter. It has seen a lot of work and has been very reliable.
Me personally only own a lot in the city so I thought I could buy a cheap Ryobi 2 cycle straight shaft trimmer. Well I used it for a year and the gear head at the end of the shaft was wrecked. SO I had it rebuilt under warranty and tried to use it for a second summer, well about 1 month into that summer the gear head started making noise again. So I sold it and bought a FS 85 Stihl. The Stihl is way over kill for my lot but I will never have to worry about it. And when I move out of the city it will do everything I want it to.
So my opinion is, buy a pro grade Stihl trimmer you won't regret it.
Joel Harman
07-31-2003 05:07:12
I have had a shindiawa t-27 since 1990. I have run it with string & cleared a considerable amt of brush with a saw blade on it. Blade had chain saw teeth on it. Sharpened it just like one does a chain saw.
Had the carb rebuilt last year. Only real maintainence on it.
Kydirtfarmer
07-31-2003 04:24:42
Stihl trimmers are as good as you are going to get. I have one that is about 7 years old, and a newer one (about 2 years old) We keep our farm groomed, and looking like a golf course. The weed-eaters get hammered. The Stihl is the only one that has held up to our torture. I believe that mine are model 55s (????) The dealer where I buy my trimmers, was showing me a new model the other day. It uses a new technology starter. When you pull the rope, you wind a spring that releases at a certain point, starting the motor. I started it by pulling the rope VERY SLOWLY, and with one finger. The new starter, like Stihl trimmers, carries a lifetime warentee. There is a differance between "consumer grade" weed-eaters, and the commercial ones. The biggest difference is the better ones are re-buildable. Hope this is of some help. Bill
HAnoverTom
08-01-2003 05:07:17
 Re: Re: String trimmers in reply to Kydirtfarmer, 07-31-2003 04:24:42
The easystart system is different from the elastostart. Elastostart has a shock in the pull cord , easystart is like original post, just easy to pull
Roy in UK
07-31-2003 06:41:49
Its called "elastostart" I think.
I use a Stihl FR85 "knapsack" brushcutter and I love it. I have had it 4 years with no problems whatsoever.
Roy in UK...post script
07-31-2003 11:31:49
 Re: Re: Re: String trimmers in reply to Roy in UK, 07-31-2003 06:41:49
I notice that our local council Parks and Gardens dept. have changed their trimmers from (? they were yellow ?) to Stihl
michael
06-18-2004 13:26:58
 Re: Re: Re: Re: String trimmers in reply to Roy in UK...post script, 07-31-2003 11:31:49
I have a Stihl FS 36 that runs fine. However, the push ball (primer) is cracked and I need a new one. Any suggestions on where to get such a part? How about a parts list or breakdown?
Also, I have a Stihl 023 chainsaw and could use a good parts source (preferably online) for that as well.
Thanks
