Guys, thanks for the replies, sorry that I did not give an important detail or two - this lead to most of you having to type about stuff (220 vs 120 volts) I already knew ... again sorry. The generator only puts out 120 volts; it is a maximum output (for short burst to start things like an air conditioner compressor) of 3000 watts (or, as listed in manual specs, 3.0 kVA), rated (sustainable) output of 2800 watts (2.8 kVA) divided by 120 volts = the rated ampere of 23.4 amps (as listed in manual). It is not a 220/230 volt system. The 30 amp outlet is round with 3 prongs, one L-shaped (which, according to the wiring diagram is the ground) and two paddle-shaped prongs. One of the paddle-shaped prongs is supposed to be connected to the red wire (according to the diagram), and the other to the white wire, which is the one I expected to be hot. But, as I said, they both have juice flowing to them. It's not just the 30A outlet; when I use my test light in the 20 amp outlet (which looks exactly like the 15 and 20 amp outlets in our houses), both the red and white wires (i.e., both paddle-shaped holes) are hot, just as with the round 30 amp outlet. Does anyone know whether or not this is a typical situation for generators which is different from domestic electric supply? I did get the 30A plug from a Honda dealer; and I have never seen a generator that has a triangular outlet like the one they use on campers - I think it has more to do with differences in industry convention than some consistent building code (campers do move from town to town and state to state). The multi meter sounds like a good investment (I'll tell the wife that you all said I need it!). Thanks again for your replys; hope to read more.
