Tool Talk Discussion Forum
Perma-coil vs. Helicoil Thread Repair
Andy
07-30-2003 19:48:25
Went to buy a 5/16" thread repair kit today and found that the supplier offered both Helicoil and Perma-coil brands. The Perma-coil is quite a bit cheaper and looks to be the identical thread insert as Helicoil. Any reason I shouldn't use the cheaper Perma-coil?
Larry
11-04-2003 14:42:54
 Re: Perma-coil vs. Helicoil Thread Repair in reply to Andy, 07-30-2003 19:48:25
We like the perma-coil because the installer does not break.Helicoil installer is plastic and breaks after a few uses.Our local jobber does not sell them anymore.Anyone know where I can get a new supplier in central michigan.Thanks in advance.
Bus Driver
07-31-2003 05:29:07
My guess is that the Helicoil patent has expired. I have used other brands of inserts with my Helicoil taps and the results were quite satisfactory. Use the Perma- Coil.
