Tool Talk Discussion Forum
Super 2 chain lube is running into crankcase
Jay
07-29-2003 21:41:30
My chain lube is going into the crankcase. I assume I need to replace the diaphram. Who carries the parts and where can I get a parts list/repair manual ?
Stihltech
07-30-2003 19:00:20
 Re: Super 2 chain lube is running into crankcase in reply to Jay , 07-29-2003 21:41:30
Go with the duckbill valve. The plastic tank is separate on ths model. The valve will fix it 90 % of the time.
RWK in WI
07-30-2003 19:00:05
Check the "duck bill valve" on the end of the tube line going into the oil tank. Sometimes these drop off the line and allow the oil to go back.
John in MA
07-30-2003 10:30:32
The diaphragm and duckbill valves are failure points for the Super2.
Any Homelite dealer can provide the parts, and Homelite at least used to send you parts breakdowns if you asked. RCPW.com sells Homelite parts online but you need the part#.
koontz
07-30-2003 03:16:15
some of the small chainsaws were bad about this, your super 2 homelite might be near retirement, i think there is a product sold to coat the inside of your bar oil tank, like an expoxy material??
my 3cents
