Tool Talk Discussion Forum
Riding mower help
Renee
07-29-2003 06:26:10
Hello all. I have a riding mower that dies when the deck is engaged. Any idea as to what might cause this? Thanks
Ben in KY
07-29-2003 12:44:07
 Re: Riding mower help in reply to Renee, 07-29-2003 06:26:10
Does your mower engage the deck with a switch or lever ? If it is a switch then it probably has an electric clutch, which could be shorted and pulling down your power and killing the spark.
It all depends on what kind of mower you have. Could you let us know the brand/HP/model, etc ?
Renee
07-29-2003 13:18:02
 Re: Re: Riding mower help in reply to Ben in KY, 07-29-2003 12:44:07
Ooops, sorry, I should know better since I go to a car forum alot. LOL. It's a 1990 Briggs & Stratton Model 422707, 18hp, 45" cutting deck, it has twin cylinders. That's all it says.
Jake
07-29-2003 07:33:56
Engage the blade slower?
Have you cleaned out the grass build-up under the deck? Neighbor had the same problem a while back and I went to look.... Just found the grass built up so thick the blades would no longer turn.
Farmer Gene (WI)
07-29-2003 06:49:04
Something wrapped around one of the blade shafts or a bad bearing, try turning the blades with the mower shut off and see if they're binding.
Mac
07-29-2003 06:45:50
Start by checking the safety swxs.
Renee
07-29-2003 06:47:36
 Re: Re: Riding mower help in reply to Mac, 07-29-2003 06:45:50
The safety what?? I am sorry, I am a newbie to mower terms pretty much. LOL.
thurlow
07-29-2003 07:28:28
 Re: Re: Re: Riding mower help in reply to Renee, 07-29-2003 06:47:36
Safety switches; depending on age and model of mower, it will (may) have 3 or more safety switches which must be correctly positioned before it will start or work; i.e. clutch pedal must be depressed; must have weight in seat; blade engagement lever must be properly positioned, gear shift lever must be in neurtal, etc.,etc..... .
Leon in MN.
07-29-2003 19:41:08
 Re: Re: Re: Re: Riding mower help in reply to thurlow, 07-29-2003 07:28:28
Sounds like the seat saftey switch to me. A common problem on all mowers.
Ludwig
07-31-2003 16:03:45
 Re: Re: Re: Re: Re: Riding mower help in reply to Leon in MN., 07-29-2003 19:41:08
I was actually thinking that the seat safety switch would be one we could definately rule OUT.
Note it dies when the blades come on. If it were the seat switch the mower shouldn't run at all.
Could be the reverse safety switch. Usually this switch works by completing a circuit when you go into reverse. If the switch wouldn't shut off then it'd think it were in reverse all the time.
Usually that switch is really easy to check too, especially on an MTD mower. If the shifter is down between your legs there'll be a plate there that comes off. Lift the plate and you'll find the switch. Disconnect the wire. If it mows fine its a bad switch.
Leon in MN.
07-31-2003 20:14:58
 Re: Re: Re: Re: Re: Re: Riding mower help in reply to Ludwig, 07-31-2003 16:03:45
I beg to disagree. It still can be the seat switch because the mower can still run and drive without the blades being in gear, (except some models in reverse with the blades on, but that is what it is supposed to do.) I have worked on many mowers over the years at my place of work and I don't know of any models that shut off the engine when the blades are OFF and you get off of the seat in PARK. The mower can run by itself with the blades OFF and no one on the seat. It is when the blades are ENGAGED and the mower out of PARK and or no one sitting on the seat when the engine can will die. If the seat switch were defective, and the blades were ENGAGED the engine would kill immediately indicating no weigh on the seat. It would also kill in all of the situations as thurlow had stated. It would also as you stated kill the engine if it had a reverse switch out of adjustment, but usually the switch fails to close leaving the switch OPEN to where the blades would come on anyways. I have worked on these for many years and usually, but not always, the seat switch is the one to fail if it is in the saftey curcuit and in PARK. My $.02
