Tool Talk Discussion Forum
Steel cost
Ted
07-24-2003 12:59:44
Just paid $90.00 for 14 feet of 3/16 x 1 1/2 x 3" steel tube did I get taken or is that about right? Thanks
RANDY
08-15-2003 11:33:13
 Re: Steel cost in reply to Ted, 07-24-2003 12:59:44
BOY I LIKE TO BE YOUR STEEL SUPPLY HOUSE!
ID BE RICH OR IN PRISON FOR ROBING FOLKS!
AT MY SHOP THAT WOULD BE $25.00
Richard
07-26-2003 06:47:15
You probably purchased the full 20' joint without realizing it. Then ended up with a cutting fee on top of that. It's cheaper "here" tp buy the entire joint and throw the left overs in a pile for use down the road.
wdTom
07-25-2003 17:16:42
You didn't say if it was new or used, seamless or welded.
ScottT
07-25-2003 10:28:17
Around here (SE WI) steel goes for $0.60 - $0.80 / lb. (depending on shape). My book lists your tubing at 4.97 lb/ft = $42-$56.
Small lot handling and / or cutting charges may be added.
Scott
ray
07-25-2003 08:02:48
Maybe the low quantity,handling fee or cut charge worked against you here. Call the yard and ask for the price/lb or price/ft (on your tubing). Price per lb should be pretty close/consistent for each mechanical tubing type. I figure you purchased 75lbs of steel. $37.50 would have been high - if theres no cutting /handling fee.
David - OR
07-24-2003 16:22:47
For the hobby projects I do, I typically use "surplus" steel. This is the rusty stuff at the back of the yard, or it has surface imperfections, dimensional problems, or all of the above.
Such steel costs a little more than 25 cents per pound. Steel weighs about 1/4 pound per cubic inch. So I just memorize 0.25 * 0.25 to get my steel cost estimate. This estimate is a bit low, but it is easy to remember.
"Prime" material in simple shapes (flats, bars, plate, angles) costs about 40 cents per pound.
"Added value" products like hollow structural sections (your "steel tube" for example) might cost a little more, but not THAT much more.
Your steel is 3/16 * (1.5 + 1.5 + 3 + 3) cubic inches per inch. That's 1.69 cubic inches per inch or 0.42 pounds per inch.
14 feet of the stuff is 14 * 12 * 0.42 or about 71 pounds. At 50 cents per pound that should have cost about $35.00
Places far away from steel mills, railroads, and port facilities might reasonably charge more for transportation costs and lack of competition. And if you need an exact size in prime quality at small quantity you may pay more for it.
But at about $1.25 per pound, my general assessment is that you did, indeed, "get taken".
The place I buy steel has a special going on random lengths of tubing. Random lengths are usually fine for home fabrication projects. Although your exact size isn't featured, you can see that steel tubing can be had for considerably less than you paid.
Karl O
07-24-2003 15:14:55
Mild steel generally runs about a buck a pound, or at least that's what the engineers around here use for estimates.
