Tool Talk Discussion Forum
Wood splitter - plans?
John A (TX)
07-23-2003 19:21:53
Does anyone know of any plans being available for construction of a wood splitter? Not having any remote hydraulic connections on my 601 tractor, I probably need to stick to gas engine-powered.
Friend of mine built one .. I haven't "gone to school" on his as yet and thought maybe someone here might know of some plans.
Thanks in advance for any suggestions.
JohnA(TX)
Bruce
07-28-2003 09:56:34
 Re: Wood splitter - plans? in reply to John A (TX), 07-23-2003 19:21:53
On more - from CADPlans
John A (TX)
07-28-2003 12:01:50
 Re: Re: Wood splitter - plans? in reply to Bruce, 07-28-2003 09:56:34
Thanks, Bruce, for the link to CadPlans. Interesting & definitely worth looking into.
ajco
07-27-2003 20:26:32
I built a 3p.h. splitter using 8in. H beam reinforced on each side with 7 in.chanel. knife 2in. plate sharpened with torch &inserted down thru. H beam. used 2 4 by 32 hyd. cyl. only bottom cyl. pinned to push block & used for small wood. 2nd cyl used as needed.pull control levers alternately to rock push block works best splitting really tough knots. A 8 ft.high swing boom with hyd. winch ,3/8 cable & home made tongs lets me pull,puck up & split blocks up to 5 ft. dia. & 30 in long.To slow winch when splitting a large hinge was modified with adjustable stops & flips over hyd. control lever to limit its movement. flips out of way to run cable out fast for another block of wood. Push block has sides extended below H beam &bolted together with 4 -3/4 by 10in. bolts thru. pipe rollers.
koontz
07-25-2003 18:06:34
john, forsure, get a two stage pump,,the last one i built (the 4th) & i hope the last, i purchased a used behind the tractor 3 pt spliter, used the beam & cyl.. mine has the knife at the rear like some one mentioned.. put a trailer axle which i shortened in width w/springs.. the beam is crouch heigth so i don't bend over using it. i went with a 8hp cause i had one but a 5hp or bigger will work fine, the value returns the cly. then automaticlly stops & waits to be sent forward again (pump & valve from northern tool..got a hyd. tank from an old implement, use a vent on tank, get a filter from n.t. also.. mine is painted black & gold(go purdue)i'm a forester
Chuck
07-28-2003 09:50:22
 Re: Re: Wood splitter - plans? in reply to koontz, 07-25-2003 18:06:34
John .... about the same approach but red w/ a white 'W' seemed to make it much more powerful
John A (TX)
07-28-2003 11:59:20
 Re: Re: Re: Wood splitter - plans? in reply to Chuck, 07-28-2003 09:50:22
I dunno, Chuck. I sorta think it ought to be Maroon & White. :-)
CTR
07-24-2003 20:08:34
I have built 3 on my own that operate off tractor. I always "push the wood to the knife", meaning the "knife at the end of the beam", this always keeps the split wood at the far end, not under your feet. Also weld guides on the push block to keep on track as moving on the beam. I made this all from scrap hardly cost anything.
Ron from IL
07-24-2003 07:28:21
John,
Check with Northern Tool & Equipment (formerly Northern Hydraulics). They have a how-to construction manual available.
Ron
JohnA-TX
07-24-2003 14:41:14
 Re: Re: Wood splitter - plans? in reply to Ron from IL, 07-24-2003 07:28:21
Thanks, Ron. I'd looked at Northern Tool for some trailer plans not long ago but didn't remember seeing anything else. Will take another look.
Thanks again ..
John
Bill R
07-23-2003 23:48:54
Hi John,
There are two descriptions of wood splitters in the Lincoln publication "Arc Welded Projects Volume II". The book has a lot of good ideas, and is only $5. Well worth it. The link is>Link
They're pretty simple. I'll get around to making one soon...my wife's starting to ask about all of the piles of wood here and there...
JohnA-TX
07-24-2003 14:43:00
 Re: Re: Wood splitter - plans? in reply to Bill R, 07-23-2003 23:48:54
Thanks, Bill. Wasn't aware of any of Lincoln's publications but will sure take a look. Another good source!
Regards,
JohnA(TX)
Jim
07-25-2003 18:50:46
 Re: Re: Re: Wood splitter - plans? in reply to JohnA-TX, 07-24-2003 14:43:00
Hi John and gang. When I biult my woodsplitter I did a bunch of research by looking at ideas people had on the net and by checking out where they were sold. I took my camera and paper and spent my time looking and planning.
I biult mine with a moveable knife on a piece of I beam. I like the moveable knife so I don't have to chase the wood. Both pieces stay right there and then gets tossed on to the pile.Also don't biuld it to low your back will pay. I took the cheap way with the prime mover. I took the 10hp off of my snowblower saved a few bucks that way. I also managed to scrounge a couple of poly chain sprockets from work as well as the poly chain so power gets to my pump fairly efficiently. I had to go with a jack shaft arrangement because my pump turned different from my motor. Oh my Pump? I scrounged it from work also, its a hyd pump for a john deere backhoe that was taken off and put on the scrap shelf because someone (not me)didn't know how to troubleshoot properly. It has a 20 gpm pump for the main and then a 9gpm for the power steering (on the hoe). I took the bottom gear out of the 20 gpm section and just use the 9 gpm. A two stage would have been nice but I like to try things different and save a few cents. Just remember for a rule of thumb you need 1 hp for every gpm of your pump.( This is fine with a electric motor but gas motors would work better with a factor of 1.25 hp or more per gallon per minute)Well this is getting to long will watch and post more of what I created if anyone else wants to know. Oh yea I use a 3 1/2 inch cyl with 24 inch stroke Never had a problem with the hyd to split birch spruce and fir up here in Canada.
Barry
10-01-2003 06:51:09
 Re: Re: Re: Re: Wood splitter - plans? in reply to Jim, 07-25-2003 18:50:46
Good comments Jim. I'm just starting to research building my own splitter. I've never used a splitter (got by so far with brute force) and wonder if any of you guys have experience with one on BIG (30") blocks of ELM? Oak, pine, maple etc are CHILDS PLAY! ha ha
One of the big factors would be how far the wedge goes into the block....needs to go all the way through for elm!
John A (TX)
07-26-2003 14:15:43
Dang, you guys are creative! Thanks, Jim. Am beginning to think that - from what's there in the plans plus what you guys can offer in the way of critiques - I shouldn't have too much trouble putting one together.
Ordered Northern's "how to" booklet a day or two ago, so it ought to be here next week. Then I can get started acquiring materials!
Thanks again, y'all.
~ja
Robert Sigler
10-18-2003 04:36:25
 Re: Re: Re: Re: Re: Wood splitter - plans? in reply to John A (TX), 07-26-2003 14:15:43
What kind of hydralic oil does a little giant log splitter take. It's a 1984-85 model???
John H
11-03-2003 12:00:37
 Re: Re: Re: Re: Re: Re: Wood splitter - plans? in reply to Robert Sigler, 10-18-2003 04:36:25
If it runs hot, use an ISO 68 hydraulic oil. Otherwise use an ISO 32 or 46 hydraulic oil.
