Tool Talk Discussion Forum
Black Decker valve grinder parts needed
Geoffrey in KS
07-22-2003 20:37:11
Does anyone know where I can find the attachment for grinding tappets, rocker arms and valve stems? It goes to a Black & Decker Type A valve grinder. I am also looking for the collet that accepts 1/2" to 11/16" and the one for extra small valves. If any one has one of the original black & Decker cabinets for the valve grinder, I would also be interested in that.
Thanks,
Geoffrey
J Hesler
08-06-2003 14:07:20
 Re: Black Decker valve grinder parts needed in reply to Geoffrey in KS, 07-22-2003 20:37:11
Geoffrey: Goodson has a lot of parts for these machines, "goodson.com".
wrenchman
07-23-2003 20:23:12
iirc the replacement collets for older KO-Lee valve grinders will fit with very little alteration(spacer length)...that's what i put in mine,works good...you need the outside diameter of your collet to match em up...kinda expensive new though,like around $120.00+ each...OUCH!!!...done a LOT of searching & was only new ones i found that would work...you may have better luck...
Mike M
07-23-2003 07:59:12
Try calling this guy he used to deal in these I bought mine from him. Don Walkerow in Ohio 330-378-2741
David G Gray
10-12-2003 09:54:46
 Re: Re: Black Decker valve grinder parts needed in reply to Mike M, 07-23-2003 07:59:12
Im looking for a pump seal for a Black and decker super services valve grinder ser no,2654191.
Thank you David G Gray
