Tool Talk Discussion Forum
farmall 504 hydraulic leak
john
07-22-2003 18:31:15
I have a 1969 farmall 504 that has started leaking (pumping) hydraulic fluid from the gearshift lever. It is not leaking between the main body and the housing that holds it. It is coming up from around the gearshift itself. Is there another gasket or oring that could be missing.
oilleaknotok
07-23-2003 04:06:25
 Re: farmall 504 hydraulic leak in reply to john, 07-22-2003 18:31:15
Your transmission oil level is too high. Drain the oil down to the proper level and determine why it is over full.
