Tool Talk Discussion Forum
Best Cleaner for varnished carb
KX
07-22-2003 07:19:54
What is the best thing to clean out a gummed up, varnished small carb (5hp Honda engine).
J Hesler
08-06-2003 14:11:08
 Re: Best Cleaner for varnished carb in reply to KX, 07-22-2003 07:19:54
I think it's shellac not varnish that has your carb gummed up. Denatured Alcohol works great.
Tom_NC
07-22-2003 20:09:26
Auto Zone sells a cleaner that comes in a gallon can (like a paint can). Take the carb apart and remove any plastic / rubber parts, put it in the basket in tha can and leave it for 15 min or so. Comes out clean as a whistle. Can't remember the name brand.
Tim in NB
07-22-2003 18:25:06
The best I've found is Mopar Combustion Chamber Conditioner found at your local Dodge dealer in aerosol cans.
Dick in Ore..
07-22-2003 15:57:07
Saw a mechanic use a can of that aresol brake cleaner the other day and it worked great.
Ted
07-22-2003 15:54:22
Without a doubt the best off the shelf carb cleaner I've ever used is B-12 Chemtool.I get mine at Walmart.
Unimog
07-22-2003 12:22:19
I always have good luck with lacquer thinner, but
watch out for any plastic parts.
Scott
07-22-2003 11:03:52
I've cleaned a load of carbs. Used to work for a motorcycle shop. Here's what I learned. If it says environmentally safe, go to the next can. If it doesn't have a big "Warning, Extremely Flamible" on the can, move on to another. I look for the nastiest stuff I can find. Some of the others do work, but it takes many times more material to clean the same carb.
Vern-MI
07-22-2003 10:54:17
The cleaner at Walmart works good and is only about 80 cents a can.
Mac
07-22-2003 09:53:48
I always have good luck with aer=sol carb. gumout.
On small engine carbs.
Red Dave
07-22-2003 07:41:26
Berkebile 2+2 Gum Cutter works good for me.
Be careful though, it'll eat some plastics and rubber compounds too.
KX
07-23-2003 11:47:23
 Re: Re: Best Cleaner for varnished carb in reply to Red Dave, 07-22-2003 07:41:26
Thanks for all the ideas. I bought a couple of the mentioned brands.
