Thanks for the advice. I have two tractors to be painted but that is all I can forsee unless I can paint my house with it? Will a pressure feed one spray latex house paint? I asked about the sears guns because they can be changed from siphon to pressure feed and internal to external mix. I talked to a guy at an automotive paint supply company today who told me most people he talked to didn't find HVLP guns any better and he recommended agains them. Even if they are better, I don't think my compressor will run a HVLP gun. as it only puts out 8 cfm at 40psi and 6 at 90. Any comments from anyone would be appreciated. : Siphon or pressure refers to the method by which the paint is moved to the nozzle. Siphon-fed guns use the pressure differential caused by air moving through the nozzle to pull paint from the cup. Pressure-fed guns use air pressure in the cup to push paint to the nozzle. Siphon-fed guns are usually used for thinner materials such as automotive paints (like you're probably using). Pressure-fed guns are usually used for thicker materials such as house paint. There is some overlap in usage between the two types.
: : Internal-mix guns mix the paint with air before it leaves the gun. External-mix guns mix the paint with the air after it leaves the nozzle. External-mix guns generally give more even atomization and better patterns. : : Bleeder or non-bleeder refers to how the desired air pressure is maintained. Bleeder guns maintain a constant flow of air through the gun and can be used with tankless compressors without having problems maintaining a constant pressure when starting or stopping the spray. Non-bleeder guns totally stop the air flow through the gun when the trigger is released. : : HVLP (as mentioned in another post) is an acronym for High Volume, Low Pressure. This type of gun uses large quantities of air at a low pressure and is probably the most paint-efficient way of spray-painting. With a conventional gun (the kind you're asking about), most of the paint ends up as overspray instead of on the tractor. HVLP guns will put most of the paint on the tractor and have very good atomization and spray patterns. As the other post advised, if you're going to do much painting you'll quickly pay for the HVLP gun by using less paint on each job. If this is the only thing you ever use it on, I'd just buy a conventional, external-mix, siphon-fed, non-bleeded type gun. : : Now that we've got that out of the way, on to Sears' guns. I've used their middle-price gun and it worked OK. There are less expensive guns that are of at least the same quality though (Sears' tends to be a little high on prices). Look around and see what you can find.
