Tool Talk Discussion Forum
Welding a cast intake manifold
Andy
07-19-2003 19:22:27
I have an intake manifold from a tractor I would like to modify from a 6 cyl to a 4 cyl. It's cast but I don't think real hard stuff. Should I preheat and use a nickle rod or a 7018? thanks.
george md
07-23-2003 08:23:00
 Re: Welding a cast intake manifold in reply to Andy, 07-19-2003 19:22:27
Andy, Brazing would be satisfactory , leave the nickel rod in the box it contracts at a much
greater rate than cast iron causing extreme internal stress leading to cracking.
Use torch and cast iron rod ( usually square but some are round) and proper flux , the
finished weld will be a better weld and will look like the piece that you are welding.
george
TimC
07-20-2003 20:37:31
Braze.
SHeiserman
07-20-2003 13:35:38
I'd stick with ni rod. I believe I've heard 7018 will weld cast, never tried it myself. If you go through the preheat and slow cool you won't have anything to worry about.
