Tool Talk Discussion Forum
Tool to help pressing in Wheel Bearing
John C. (ca)
07-17-2003 18:26:37
Hello
Just replaced two wheel bearings on my trailer. Had to press two of the new races into the hub. I have a big press, so the power to do it is not the problem. My question is what works to help press it in. I didn't have a socket big enough 2.75 inch across. Ended up using some Oak lumber to press it in. Are there "kits" of different sizes that would fit over the races and give a good solid base to press against? If so where could I get one for the next time.
thanks
john
Bill C.
07-20-2003 18:24:04
 Re: Tool to help pressing in Wheel Bearing in reply to John C. (ca), 07-17-2003 18:26:37
John C: I've replaced a lot of bearing races, and the neatest trick I've seen yet is to make a cut through the old race with a whiz wheel. Use it to "follow" the new race in. The cut allows it to squeeze into the bore without much tension, remove it with a light tap from the other side with a punch or just pop it out with a pair of pliers. Save the cut races, and make your own set of custom race installers.
Chas in Tn.
07-18-2003 19:48:46
Put them in a deepfreeze for about 2 hours, they will fall in place.
John C. (ca)
07-18-2003 21:08:40
 Re: Re: Tool to help pressing in Wheel Bearing in reply to Chas in Tn., 07-18-2003 19:48:46
Great Idea... I'll try it on my next one.
Thanks
John
John C. (ca)
07-18-2003 18:18:19
Thanks all for the replies. I'll check em out.
john
IMJMAC
07-17-2003 22:57:59
JOHN, I DO THE SAME AS MPK EXCEPT THAT I GRIND A LITTLE OFF THE OD SO THEY DON'T STICK IN THE HOLE.
CWL
07-18-2003 07:58:35
 Re: Re: Tool to help pressing in Wheel Bearing in reply to IMJMAC, 07-17-2003 22:57:59
Ditto
DHuth2
07-17-2003 22:28:33
We do it several ways. The tapered "Timpkin" type bearings, if you weld a bead on the surface of old bearing and let cool will fall right out of hub or counterbore.Then check for flat surface and use it opisite new bearing to press in. Or if no welder use a skinny cutoff wheel and cut through race after you drive it out. That way it wont stick in the bore when driving new one in.
buck
07-17-2003 19:34:15
Have used this method hundreds of times with no bad results. Use the old bearing to push the new race in with. Just place it in the new race an press.
Mac
07-17-2003 19:18:39
several years ago I purchased a set of C/R. Can use for a race or seal. Back then they were under 50 bucks. Lilse's tools has a set for about 60 bucks. Might check northern tools or harbor freight also. Even McMaster-Carr.
These are a pretty common item.
MPK
07-17-2003 19:47:17
 Re: Re: Tool to help pressing in Wheel Bearing in reply to Mac, 07-17-2003 19:18:39
I have a supply of old races, bushings, etc that I use for pressing bearings and races or whatever I need them for.Just find one a little smaller than the one your pressing out.
